Old 04-03-2020, 06:01 PM   #1
Vanspeed
Vanspeed's Avatar
Default Coil bracket? 42 and up
Can somebody tell me how this coil bracket works? What does it volt to? Does anybody have a picture of it installed?
File Type: jpg 199E7338-B146-46F7-9FD3-35FD9EB8D223.jpg (25.1 KB, 8 views)
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 04-03-2020, 06:12 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Coil bracket? 42 and up
Looks familiar. But maybe more like a horn bracket? Is this a quiz? 8^) Jack E/NJ
Old 04-03-2020, 06:15 PM   #3
fordwife
It bolts to the left front of the intake manifold and holds an original type coil
fordwife is offline   Reply With Quote
Old 04-03-2020, 06:15 PM   #4
petehoovie
petehoovie's Avatar
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 04-03-2020, 06:37 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
How about some REAL pictures? DD
.and the coil that mounts to the bracket!
T5 W/TORQUE TUBE
LAZINESS is the art of RESTING...before you get tired!
Old 04-03-2020, 07:16 PM   #6
Vanspeed
Vanspeed's Avatar
Thanks so much V8Coopman.
Old 04-03-2020, 07:18 PM   #7
Vanspeed
Vanspeed's Avatar
Ok well that sums up buying one, did not know they were for the original style coil. What are you guys doing when running a modern coil on a 59A engine? My coil wire is pretty short so the modern coil would have to be in around the same spot.
Old 04-03-2020, 07:31 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
I'd fashion some sort of round (coil-sized) clamp that bolts to those two holes....easy peazy! DD
T5 W/TORQUE TUBE
Old 04-03-2020, 08:18 PM   #9
G.M.
The new looking coil in the bottom picture looks like
SKIP rebuild, that's how he would mark 6 volts on
the side. G.M.
www.fordcollector.com
G.M. is online now   Reply With Quote
Old 04-04-2020, 09:52 AM   #10
1931 flamingo
1931 flamingo's Avatar
Make the coil wire longer??
Paul in CT
Old 04-04-2020, 10:59 AM   #11
TJ
TJ's Avatar
X2- take a look at the universal brackets used on the modern round coils. Some have slotted holes and may bolt right up to the earlier bracket.
Old 04-04-2020, 11:26 AM   #12
G.M.
Didn't Mcmimm in Tennessee post he had some original 39 type
coil brackets. I think he wanted $18.00 each. You don't want
some abortion hanging on the front of your engine. G.M.
Old 04-04-2020, 11:46 AM   #13
zzlegend
zzlegend's Avatar
Well, this might help you. I am not sure how Coopman found my old pictures, but that is my spare green flathead on a cart and here is pictures of my 27 roadster using that same bracket and a newer style coil like Coopman recommended. Go figure.
zzlegend is offline   Reply With Quote
Old 04-04-2020, 12:47 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Ha...You know what they say...once you post it on the internet, it's there FOREVER! So be careful about posting pics of frolicking-around with all your girlfriends! But seriously, the "SEARCH" function is priceless. I merely typed-in "1948 coil bracket" and your pics were some of several that popped-up. Much appreciated, too! And OH YEAH, great minds obviously think alike!! DD
T5 W/TORQUE TUBE
Old 04-04-2020, 12:52 PM   #15
zzlegend
zzlegend's Avatar
Thanks Coop. Ya, you did good. Hope they help vanspeed. Luckily no girl friend pictures but me and the wife????????? Now you got me wondering. Well i better double check now. Thanks and stay safe. Mark.
Old 04-04-2020, 04:57 PM   #16
Vanspeed
Vanspeed's Avatar
Thanks for the help on this guys. I know have an idea that I think will work. I cannot use the original style bracket with a modern one the way zzlegend has because my early 21 stud has a waterpump right there. No worries, I will fan something up.
Old 04-04-2020, 05:34 PM   #17
Lawrie
Lawrie's Avatar
I made a little bracket to mount a modern coil on our 34 before I found out about Skips coils, If you want I will drag it out and get a pic of it
Lawrie
Old 04-04-2020, 06:03 PM   #18
tubman
tubman's Avatar
I really enjoy making brackets. With a little planning, they are usually less than a one day project, and when they come out the way you want, very satisfying. I had a field day when I put the hemi in my dirt modified.
Old 04-04-2020, 07:05 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Me TOO! I've always taken pride in my ability to envision, and then fabricate a bracket to perform some necessary function. It's even better when it's appropriate to make a bracket or fitting out of aluminum, as I love doing fine, hand-finish work with a file to "make-pretty". DD
T5 W/TORQUE TUBE
Old 04-04-2020, 08:18 PM   #20
Lawson Cox
Lawson Cox's Avatar
the side. G.M.
Shouldn't the coil wires be attached with Ford tube nuts and not hex heads?
