10-21-2019, 03:28 PM | #1 |
Help bearing race removal F1 hub
I'm trying to get the inner and outer races out of the hub, I was able to find a socket to fit the outer race #09195 and drive it out. The inner race #14276 looks like it would need to be pulled out, I tried a punch and chisel but I didn't want to bugger up the hub. Any ideas, also best place to get parts?
Thanks |
10-21-2019, 03:47 PM | #2 |
Re: Help bearing race removal F1 hub
Run a bead of weld on the bearing surface. When it cools off it will shrink and fall out
10-21-2019, 05:22 PM | #3 |
What aspect of this are having a problem with?
I knocked quite few inner races out of all the different styles of F-1 and F-100 hubs with a regular old flat nosed punch. On the hubs with-out notches, you just got to work your way around, evenly, driving it a little at a time. |
10-21-2019, 05:28 PM | #4 |
I likewise have always used a punch.
10-21-2019, 05:46 PM | #5 |
The only punch I have is a little short, so it's quite an angle and it's messing up the inner edge of the hub. I'll take a trip to the hardware store to see if I can pick up a longer better made one.
10-21-2019, 06:08 PM | #6 |
10-21-2019, 06:15 PM | #7 |
Use a piece of keystock; the "average" stuff isn't hardened so it won't damage the bearing race and it's easy to grind to whatever angle you need on the end. What I was trained to do when I went through the apprenticeship 45 years ago...
10-21-2019, 07:01 PM | #8 |
You will most likely need a good set of drift punches for other projects anyway.
10-21-2019, 07:08 PM | #9 |
What Skidmarks said!!
10-22-2019, 08:50 PM | #10 | |
1/4" keystock is what I used when I did the job. Easy to get the right profile on it with a grinder...... just what the doctor ordered. Last edited by 1948F-1Pickup; 10-27-2019 at 11:18 AM. |
10-23-2019, 07:20 AM | #11 |
https://www.fordbarn.com/forum/showthread.php?t=271366
Got it done thanks. |
10-23-2019, 02:44 PM | #12 |
check the tool cataloges many mainstream tool brands actually supply bearing drifts which are the correct length and shape
