Old 09-14-2019, 02:30 PM   #41
Tom Endy
Tom Endy's Avatar
Default Re: Transmission Issues
A few years back the Model A hobby was inundated with poor quality clutch disks. The six springs were not secured correctly and could come loose and jam the clutch. Most suppliers by now carry a quality disk. See attached article.
However, I don't see how a clutch disk spring could get inside the transmission.
Tom Endy is online now   Reply With Quote
Old 09-14-2019, 02:48 PM   #42
chrs1961815
chrs1961815's Avatar
Originally Posted by 30 Closed Cab PU View Post
If I remember correctly, there are two types of plates that the springs fit into. One style holds the clutch springs captive, one style does not. I am not a mechanic, but wanted to raise this point, if true would hate to see him get the wrong type and encounter this again.
Perhaps others can confirm/direct him to the info? Or tell me I do not know what I am talking about.
I would like to know as well. This trans was converted to a single disk.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-14-2019, 02:49 PM   #43
chrs1961815
Getting together some people to help take the trans out to replace the disk, pressure plate, and throwout bearing. Hopefully only a few days of work. I will keep you all updated.
Old 09-14-2019, 03:02 PM   #44
Railcarmover
Drop the rear axle,split at the clamshell.pull trans and bell housing.
Railcarmover is offline   Reply With Quote
Old 09-14-2019, 03:35 PM   #45
F.M.
While it is front of you, why not the trans bearings,& pilot..I would also do a rehab on the tower..
F.M. is offline   Reply With Quote
Old 09-14-2019, 03:47 PM   #46
Purdy Swoft
Purdy Swoft's Avatar
I agree , especially replace transmission bearings while it is out !!!
Old 09-14-2019, 07:14 PM   #47
Patrick L.
Patrick L.'s Avatar
Your question about the pressure plate was answered by Tom in #41.
Old 09-14-2019, 08:16 PM   #48
ryanheacox
ryanheacox's Avatar
Yep, that’s what I have in my car... Bought the clutch kit years ago and installed it with the new engine. Crossing my fingers things stay where they’re supposed to.
ryanheacox is offline   Reply With Quote
Old 09-14-2019, 08:19 PM   #49
ryanheacox
ryanheacox's Avatar
Also, yes definitely rehab the transmission while it’s out. I didn’t when I had mine out to do the engine and I ended up pulling it 500 miles later to rebuild it. Mine needed a cluster gear. If yours is quiet you’ll probably be fine with bearings only.
Old 09-14-2019, 09:51 PM   #50
chrs1961815
As much as I don't want to cough up the money, I know sooner or later I have to do it. I am going to inspect the gears again tomorrow and make a determination.
Another funny thing is that when dissasembling some things for the overhaul I discovered that whoever restored the car used two bottom Universal Caps that were all pitted and unsightly. Luckily I have a nicer not pitted set lying around.
