09-14-2019, 02:30 PM | #41 |
Re: Transmission Issues
A few years back the Model A hobby was inundated with poor quality clutch disks. The six springs were not secured correctly and could come loose and jam the clutch. Most suppliers by now carry a quality disk. See attached article.
However, I don't see how a clutch disk spring could get inside the transmission. |
09-14-2019, 02:48 PM | #42 | |
"The more things change, the more they stay the same." |
09-14-2019, 02:49 PM | #43 |
Getting together some people to help take the trans out to replace the disk, pressure plate, and throwout bearing. Hopefully only a few days of work. I will keep you all updated.
09-14-2019, 03:02 PM | #44 |
Drop the rear axle,split at the clamshell.pull trans and bell housing.
09-14-2019, 03:35 PM | #45 |
While it is front of you, why not the trans bearings,& pilot..I would also do a rehab on the tower..
09-14-2019, 03:47 PM | #46 |
09-14-2019, 07:14 PM | #47 |
Your question about the pressure plate was answered by Tom in #41.
09-14-2019, 08:16 PM | #48 | |
09-14-2019, 08:19 PM | #49 |
Also, yes definitely rehab the transmission while it’s out. I didn’t when I had mine out to do the engine and I ended up pulling it 500 miles later to rebuild it. Mine needed a cluster gear. If yours is quiet you’ll probably be fine with bearings only.
09-14-2019, 09:51 PM | #50 | |
Another funny thing is that when dissasembling some things for the overhaul I discovered that whoever restored the car used two bottom Universal Caps that were all pitted and unsightly. Luckily I have a nicer not pitted set lying around.
