01-03-2020, 10:59 PM | #1 |
A-bone parts lot: Distributor, 2 tooth steering box parts, leftovers
City:
Champaign
State:
Illinois
Price:
30
Two tooth steering box and parts (sector shaft bushing and sector gear slightly worn, mostly there), spindle bushings, spindle kingpin felt. Windshield swing arms and nuts (finish is rusty), working brake light switch, 3 sparkplug connectors, starter switch parts, distributor (missing clamps, has modern top plate, pulled from running engine, has worn top cap track so there's a makeshift shim). Used hoses, kingpins for rod or A without mechanical front brakes, coolant petcock, 6V ignition coil (was on '52 Ford), points, condenser, handmade starter-mount fuse block. |
