02-23-2014, 05:11 PM | #1 |
Lock Washers or no??
If a bolt gets a cotter pin is there ever a lock washer also...for instance the u-bolts on front spring perch...drilled for cotter pins but mine had lock washers...and nuts will not tighten down far enough to get cotter pins in...
02-23-2014, 05:32 PM | #2 |
Re: Lock Washers or no??
Lock washers and a nut and a castle nut & cotter pin both captivate the nut so it won't back off. I suspect that at some point who ever worked on the front end had a lock nut but not a cotter pin. At least he had the sense to use one. You don't need both I tend to use what was originally intended for the item being worked on. Tim
02-23-2014, 05:49 PM | #3 |
There is no need for a washer behind a castellated nut. None were ever used as far as I am aware.
R.H.D. Author of Model 'A' Ford technical manuals. Supplier of good original RHD parts. |
02-23-2014, 06:47 PM | #4 |
Something to think about ...............
Car manufactors, today, never use a lock washer on any thing ! MIKE (mikeburch) |
02-23-2014, 07:09 PM | #5 |
the 4 large rear engine mount bolts require both a locknut and safety wire. See Restoration and Judging stds, engine section. While not cotter pins, Ford did think that using one form of locking fasteners did not always obviate the other.
02-23-2014, 08:11 PM | #6 | |
but also something to think about is how often does one drive down a dirt road thats all wash-boarded?
1929 Model AA - Need long splash aprons! |
02-23-2014, 08:58 PM | #7 |
How would a judge see the four bolts that are safety wired under the flywheel?
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
02-23-2014, 09:02 PM | #8 |
Lock washer is useless on the original Ford nuts used for the front and rear spring.
They are very hard, a file hardly leaves a mark, so the lock washer can not do its job. The lock washer can not dig in and hold. |
02-23-2014, 09:21 PM | #9 |
They also make use of Loctite. Loctite is actually more secure than a Lockwasher.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
02-23-2014, 09:54 PM | #10 |
I use them sometimes with castle nuts to get the cotter key holes to line up. Flat washers also. But I don't put my cars up for judging.
02-23-2014, 11:56 PM | #11 |
02-24-2014, 12:05 AM | #12 | |
Oh,i have float a motor mounts on my car, learn something every day!
02-24-2014, 06:09 PM | #13 |
oh yea and not much of it either. i bet theres some guys job it is to calculate how much the cost of each car to build is if they use one more oz of loctite
02-24-2014, 06:17 PM | #14 |
Haven't you heard of the new Xray program that will be utilized on all Blue Ribbon cars judged, starting this summer?
Blackwall Panthers Nor Cal chapter |
02-20-2016, 04:46 PM | #15 | |
Need to know how the rear mount was wired. |
02-20-2016, 05:03 PM | #16 |
No Washers! Hi!
www.whidbeymodelaclub.com |
02-20-2016, 08:35 PM | #17 |
I don't have a picture, but it would be a figure 8 with the wire going through the holes in such a way that if the bolt tried to unscrew it would pull the wire tighter.
02-20-2016, 09:21 PM | #18 |
Here are a few methods: Thanks to supplier of photo, and as Tom Says.
02-21-2016, 10:42 AM | #19 |
Just wondering Mr. Lopez, did you install the anti squeak shim at the top of the spring pack or the slippery shims between the leaves? Both are going to make the spring assy. thicker. Those items are not needed.
02-21-2016, 03:33 PM | #20 |
Do a google search - you will find some data that show lock washers actually make things easier to undo!!! ( and of course, perversley, some data that shows that they do work!)
