Old 05-01-2012, 09:11 PM   #1
jcheshire31
jcheshire31's Avatar
Default Brakes Dragging In Reverse.
Backed out of the driveway this morning and noticed what felt like the right front brake dragging. I say right because when I was backing out the steering wheel turned to the left. (Counter clockwise) The sedan has hydraulic brakes on it. And we just redid the front wheel cylinders. So i'm sure that has something to do with it.
jcheshire31 is offline   Reply With Quote
Old 05-01-2012, 09:28 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Brakes Dragging In Reverse.
Remove the drums and look for wet linings. I've been helping my friend with his 29 Stutz and have a heck of a time with the brakes. The rears are mouned vertical, and with the bleeder in the center, it's hard to get all the air out.
Just gotta love those mechanical brakes on the Model A.
Old 05-01-2012, 09:38 PM   #3
jcheshire31
If I had it my way I'd put the mechanical brakes back on. But this was done before we bought the car so I just kind of have to deal with it. I guess I'll switch it back once it comes times to do a ground up resto again.
Old 05-01-2012, 09:43 PM   #4
1931 flamingo
1931 flamingo's Avatar
Make sure the push rod on the M/C has a little play to it, also how much drag on the front shoes. Do you know what year brakes (I assume early Ford) you have???
Paul in CT
Old 05-01-2012, 10:19 PM   #5
Cape Codder
Cape Codder's Avatar
jcheshire31,
I had a hydraulic brake system on my car when I bought it. I have since replaced it with mechanical brakes including cast iron drums. They work great and won't be going back. Can be done without doing a ground up resto as that is how I did mine.
Joe grobleski
Cape Codder
Cape Codder is offline   Reply With Quote
Old 05-01-2012, 11:22 PM   #6
jcheshire31
I was told they were 46-48 Ford brakes. And Cape, I know it can be done but as long as they keep working right I'll stick with them until I do a ground up and change a lot of other things that I want to change.
Old 05-02-2012, 08:16 AM   #7
1931 flamingo
jcheshire31: Go to the EV8 forum and do a search for postings by richard lacey (lacy), he's a ford brake guru and has posted detailed adj procedures for the 2 diff styles of hyd brakes. Or, has your "opportunity" cleared itself up??
Paul in CT
