12-23-2014, 10:30 AM | #1 |
blown head gasket
How to definitively diagnose a blown head gasket..I have lots of water vapor coming out tail pipe on brand new engine??
The only thing worth learning is what you learn after you know it all !! |
12-23-2014, 10:47 AM | #2 |
Re: blown head gasket
take the radiator cap off and then start it up. Look for bubbles in the water. Check the oil and if it has a mucky cloudy look, that is water getting into the oil. If so, you might want to retouque your head a few more times to see if it seals up. A really good quality copper gasket and tack spray helps as well. Good Luck !
12-23-2014, 11:47 AM | #3 |
Perform a compression check. All 4 cylinders should within 5 lbs.
AL in NY |
12-23-2014, 11:51 AM | #4 |
leak down X2
12-23-2014, 12:14 PM | #5 |
Thanks guys, no bubbles in water and beautiful clear oil which is new at start up of engine...what set me off is steam and some water at start up..after about one minute of running the steam goes away as does water..re torqued head bolts this morning to 55 foot pounds..I only had them at 50 for fear of stripping bolt..maybe I'm just paranoid with this brand new $5,000.00 engine...it has only been run four times for half hour to hour...runs good..thanks for help..Dick
12-23-2014, 12:26 PM | #6 |
12-23-2014, 01:01 PM | #7 |
Time to retorque the head if you have let the new motor warm all the way up a few times.
I did have a head gasket leak water into a cylinder over night,motor would hydro lock almost when starting. Now that was a good bit of water coming out the pipe! |
12-23-2014, 01:07 PM | #8 |
maybe your muffler is filled with water
12-23-2014, 01:09 PM | #9 |
[QUOTE=Wick;1003160]Time to retorque the head if you have let the new motor warm all the way up a few times.
/QUOTE] x2! |
12-23-2014, 01:41 PM | #10 |
12-23-2014, 05:18 PM | #11 |
"steam and some water at start up"
this is normal behavior for any internal combustion engine. Good idea on the re-torque! never hurts
'31 180A |
12-23-2014, 05:47 PM | #12 |
O.K. I re-torqued the head and took compression test...all cylinders the same at 60 pounds...no bubbles in radiator..maybe I was just paranoid..thanks for help ...Dick
12-23-2014, 06:16 PM | #13 |
"new engine" "60 pounds" ?
Paul in CT |
12-23-2014, 07:33 PM | #14 |
prolly rings not fully seated yet and variance of compr. testers
'31 180A |
12-23-2014, 07:43 PM | #15 | |
www.whidbeymodelaclub.com |
