01-29-2020, 01:23 PM | #1 |
spark plug connector pictures
I am never going to show this car so I should have bought the first years series of plug connectors instead of the offset ones for my '31. But since I have a '31 this is what I ordered and I don't know why or which orientation the offset goes,the early ones were a no brainer,straight. I know it does not matter if not shown I guess but if I am to install them I guess I would like to do them correctly. Must be some reason Ford changed to this.
"Never complain,never explain"... Henry Ford II |
01-29-2020, 01:26 PM | #2 |
Re: spark plug connector pictures
two to the left. two to the right. fore and aft of center. he-he. ken
01-29-2020, 02:40 PM | #3 |
Got it I think.Good thing I am a Navy vet.Thanks Ken.
01-29-2020, 03:44 PM | #4 |
I thought it was one on the left and three on the right ??
01-29-2020, 03:48 PM | #5 |
I never thought about that. I'm so anal I'm going to have to go out and check now!
I heard Ford cut them that way to cut costs, less scrap. |
01-29-2020, 04:09 PM | #6 |
If the cross fire happens to you, it can take finding unless you are aware. I'd rather prevent it happening.
01-29-2020, 04:30 PM | #7 |
The pictures are correct. 1234
01-29-2020, 04:56 PM | #8 |
Which picture? I have different positions between them?
01-29-2020, 04:32 PM | #9 | |
01-29-2020, 05:48 PM | #10 |
So the reason for the change in 1930 was to eliminate cross firing between the connectors?
01-29-2020, 09:18 PM | #11 |
If the later ones are longer, that may be the reason. When I lengthen them, I add about 10 mm (3/8")
01-30-2020, 11:14 AM | #12 |
01-29-2020, 10:11 PM | #13 |
The offest was to use less bronze. they interlink...
01-29-2020, 11:30 PM | #14 |
I would wager they never had a thought about the direction of the offset at the factory especially close to shift change!
01-30-2020, 10:06 AM | #15 |
I would position them so they are farthest away from each other...
