04-12-2016, 09:45 PM | #1 |
1931 1932 1933 BB Big Truck Help
Okay. I am hopeful there are some folks here who can help me.
I have a big truck I trying to save from the recycler. It is a 1932 SWB truck. I also acquired a 33 LWB chassis. I also have some Model A components. 32 Front end was bent so replaced with 33. The 32 rear is in place. Tranny is from the 33. Bolted up to the 32 Bell and Model A Motor (4cyl). Thought all was good but flywheel rubs on something, Maybe the starter (also A) Or something else. I can take pics to help ID this all and I have other parts that were part of years of pickin. Need some guidance and share what works. Thanks in advance! Dennis |
04-13-2016, 04:03 AM | #2 |
Re: 1931 1932 1933 BB Big Truck Help
Rubbing? I seen a share of the ring gear not seated and rubbing on the block...
got to heat it and seat it till it registers. |
04-13-2016, 11:10 AM | #3 |
What flywheel housing are you using? If you have a B pan and flywheel
housing you need a B flywheel. Also if the starter bolts are to long they can rub the flywheel. Bob |
04-13-2016, 11:11 AM | #4 |
Check the starter bolts. I've used standard bolts out of the bin before and they were too long.
04-24-2016, 10:22 AM | #5 |
I'll do that. Thanks. Will report - Dmac
04-24-2016, 11:58 AM | #6 |
Charlie Stephens |
Thread Tools | |
Display Modes | |
