Old 08-23-2019, 11:49 AM   #1
bob1972
Default Which pressure plate to order?
I want to replace the pressure plate setup in my 1935 Ford pickup with a 1948 flathead in it. The actual plate measures 9 1/2 inches. I ordered a 9 inch plate...it's too small. What to order? Where would I find the 9 1/2 inch plate for sale? I've seen 10 inch and 11 inch plates in catalogs, but not 9 1/2.
Thanks
Bob
bob1972 is offline   Reply With Quote
Old 08-23-2019, 11:54 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Which pressure plate to order?
What size was the disk that came out? My guess is what you have is a flywheel that accepts a 10" clutch.
Old 08-23-2019, 01:19 PM   #3
19Fordy
19Fordy's Avatar
I think deuce roadster is correct. If 9 in. is too small and 11 in.is to big, 10 in. is probably correct.
Old 08-23-2019, 01:24 PM   #4
19Fordy
19Fordy's Avatar
bob, Read thru all of this thread for some helpful info.
https://www.jalopyjournal.com/forum/...an-8ba.423405/
Old 08-23-2019, 02:16 PM   #5
bobH
If it's a 48, then WHICH 48? If it came from a car, it would be a 59-type. If it came from a pickup, it would be an 8BA. Check 8BA clutch stuff. I think you will find a 9-1/2.
If it's 48 car, 59-type, it was originally equipped with a 10-inch. If it's an 8BA, look at 49-up car clutches.
edit... read hamb thread noted above by 19Fordy !!
bobH is offline   Reply With Quote
Old 08-23-2019, 03:10 PM   #6
Angledrive
Angledrive's Avatar
My go to clutch people are Fort Wayne Clutch. They will rebuild what you have or send you what you need.
Angledrive is offline   Reply With Quote
Old 08-23-2019, 08:12 PM   #7
flatford8
flatford8's Avatar
I got a 9 1/2” for a 8BA from Fort Wayne......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 08-23-2019, 08:15 PM   #8
Tinker
Tinker's Avatar
Haven't heard anything negative from fort wayne stuff.
Old 08-23-2019, 10:28 PM   #9
deuce_roadster
I never have owned an 8BA nor heard of a 9 1/2" old Ford clutch. Learned something new!
Bob1972, is that engine an 8BA?
Old 08-24-2019, 07:02 AM   #10
bob1972
Yes, the engine is an 8BA. I'll contact Fort Wayne Clutch. Thanks!
Old 08-24-2019, 07:46 AM   #11
Gene1949
Gene1949's Avatar
Dual Friction Clutch Includes Pressure Plate & Disc
Part Number : 183-DF021221
I couldn't be happier and the price was right from Jegs (drop shipped from Centerforce).
They pretty much have all transmission applications (disc) covered
Gene1949 is offline   Reply With Quote
Old 08-24-2019, 02:53 PM   #12
Ol' Ron
Ol' Ron's Avatar
The 9 1/2 was popular in the 8 ba engines, and is a good clutch in it's stock form and lighter than the 10/11" . However they di have a different bolt pattern than the early 9" so the flywheel had to be redrilled for use on an early flywheel. Now tha i said all that. I don't know if the fingers will clear rhe early 1 3/8 input shafts. The one I have is in a 59 with a T-5 trans. At present I haven't driven it so??????
Learn sumpin every day.
