Old 03-12-2019, 11:05 PM   #1
Steve Plucker
Steve Plucker's Avatar
Default The Drum Taillight electrical assembly
I have some drum taillight assemblies and am wondering how to remove the bakalite fixture on the back of the assembly.
I know for one that you press the little button down that is on the upper outside top of the Taillight socket assembly. However there is a "mushroom" shaped pin on the inside that is connected to a fixture that is riveted to the main body of the bracket.
I am sure that one does not need to remove the rivet just to remove the bakalite piece so is it that the "mushroom" pin just needs to be pulled out to replace the bakalite piece?
Thanks.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Old 03-13-2019, 02:44 AM   #2
Dan Partain
Dan Partain's Avatar
Default Re: The Drum Taillight electrical assembly
Pluck,
I don't really have an answer for you, but I can tell you what I've seen and maybe some choices. First off, I've tried to put a socket into the rear housing/license plate bracket, and I don't see any way to do it without bending, shortening one leg of the tab, or removing the rivet.
The little tail that goes under the post in the socket must have been installed by riveting that part of the assembly. I think they slipped the tab under the post and installed the rivet for that assembly.
I've seen where that tab has been bent into an S or U shape to help remove it.
I also have a few that have one little leg of the tab shortened (see photos) but I haven't tried that method in removing, or installing, the socket.
-DAN
Dan Partain is offline   Reply With Quote
Thread Tools
Display Modes
