Old 03-11-2019, 01:10 PM   #1
alexiskai
alexiskai's Avatar
Default Options for repairing shift lever ball
I've seen a lot of discussion about repairing a worn shift lever ball, and the assumption always seems to be that one would weld it up and then grind it down to .490. Has anyone tried cutting the ball out and replacing it with a 1/2-inch bearing?
I ask because I'll be paying a machine shop to do this job, so time is money. If replacing the ball is viable, and faster than welding and grinding, that might be the way to go. On the other hand, if having a spherical shape is not actually the important thing, maybe the traditional way would be best.
I guess I'm trying to figure out what I should tell the machine shop their goal is. Thanks everyone.
Old 03-11-2019, 01:18 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Options for repairing shift lever ball
The attached article may be of help. We made a jig that attaches to a grinding wheel to grind the ball after it was welded. We were able to do a number of them very quickly.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 03-11-2019, 01:31 PM   #3
alexiskai
alexiskai's Avatar
This is cool, is there a reference for the correct dimensions for the shifting fork slots?
Old 03-11-2019, 03:44 PM   #4
Joe K
Joe K's Avatar
I think you can examine your existing slots and find the "unworn" portion to make gauge to. The handle tends to set at certain positions while operating - and these become more worn than the rest.
In my case I had a choice of several transmissions to take the slots out of - so I chose the best.
In your case, if you're engineering both ball and slot, you may do well to expand the slot slightly and expand the ball to match.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-11-2019, 06:51 PM   #5
denniskliesen
denniskliesen's Avatar
Usually if a 1/2" washer will go over it as a gauge for finish size.
denniskliesen is offline   Reply With Quote
Thread Tools
Display Modes
