06-18-2018, 02:53 PM | #1 |
New master cylinder
Hi guys I'm new to this site. I have a 55 Victoria 272cu.in. w/a Fordomatic. I'm looking to upgrade the master cylinder to a duel cup. I know there was a video at one time that was on you tube, but that's been taken off. I know it was a 67 Mustang drum/drum master. Does anyone know what the other parts were. Thank You.
06-18-2018, 05:58 PM | #2 |
Re: New master cylinder
If you are retaining four wheel drum brakes, there really isn't much else you need. The MC has to be drum/drum.
EDIT - ... and MC either MANUAL or POWER ASSIST, depending on how you will be going... Referring URL- https://www.jalopyjournal.com/forum/...estion.595162/
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-18-2018 at 06:35 PM. |
06-18-2018, 07:03 PM | #3 |
The length of the brake pedal rod may be different? There should (only) be a very slight amount of end-to-end play in the rod between the pedal and master cyl.
You'll also need at least 1 new piece of steel brake line and a couple fittings. . Last edited by dmsfrr; 06-19-2018 at 10:32 AM. |
06-19-2018, 09:29 AM | #4 |
Curious, why change to a dual cup M/C? and why is that an up-grade?
06-19-2018, 09:57 AM | #5 | |
Beginning in the middle 60's brakes were upgraded to dual bowl / dual circuit master cylinders to increase the odds of still having brakes in the event of a problem, leaky wheel cylinder, etc. because half of the braking system would still function. . Last edited by dmsfrr; 06-19-2018 at 10:34 AM. |
06-19-2018, 10:10 AM | #6 | |
DRUM/DRUM Dual Reservoir MC Retrofit http://www.tbirdranch.com/64dualmc.html Quote:
THANX! for the reminder...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-19-2018, 02:45 PM | #7 |
I don't like the T-Bird's guy using Teflon tape on his fittings. But the newer master bolts right up. I kept my old push rod and the new one lengths the same. This will get you in the ball park.
The new master rear port plumbs right into the rear line. Some guys block off the rear port on the junction block and plumb the fronts the same as it was with the single master. Then comes what to do with the brake light switch. I left mine hydraulic (came with new proportioning valve) but some guys hang the new style ones off the brake pedal with a little ingenuity. Mine was a disc conversion and I had to make up a few lines for it. |
06-19-2018, 02:47 PM | #8 |
I keep the absolutely correct Master Cylinder -- when you change that single master cylinder to a dual -- no need to change rod, linkage, etc..... you DO have to address the stop light (brake light) switch situation.....
will let you know your three (3) options, there..... Call me -- Craig -- 516 - 485 - 1935...... West Hempstead, New York..... |
06-19-2018, 04:07 PM | #9 |
I don't think the duel M/Ss like 1/4 lines. JMHO.
06-19-2018, 04:32 PM | #10 | |
06-19-2018, 05:06 PM | #11 |
Never use thread tape of any kind on brake lines, or any other type of sealer. if you need this , you have a problem that needs corrected.
06-19-2018, 05:39 PM | #12 | ||
Quality flaring and quality fittings are all you should need.
06-19-2018, 06:24 PM | #13 |
OP QUESTION REGARDING DUAL RESERVOIR MC CONVERSION
-Mechanical Brake Light Switch Conversion - CLICK HERE- Plumbing in hydraulic brake lamp switch-
