08-21-2019, 08:56 AM | #21 | |
Re: Q: 34 Diff: torque on housing/ pinion preload etc.
08-21-2019, 12:01 PM | #22 |
I don't remember who I got them from. I was thinking that they might have shrunk a bit if they were cut when the air where they were made was very humid and it was dryer when I used them.
08-21-2019, 04:11 PM | #23 |
Use the best gasket kits,cheap as and make s the job a pleasure
Lawrie |
08-21-2019, 06:24 PM | #24 |
I labored over how to get the pinion setting. I ended up on Amazon checking inch lbs Torque wrenches. You can get a nice beam one for less than $20.
08-22-2019, 06:48 AM | #25 |
One thing I forgot to mention- I used an aftermarket ring and pinion and had a hell of a time getting the pre-load right on the pinion. It would be loose, I would tighten up on the nut and the outer bearing would jump and the preload would be too tight. It turned out that only the inner bearing should be a tight press fit and the outer bearing should barely be a press fit. The aftermarket pinion had the same diameter for the full length of the shaft causing the problem. I should have taken just a wee bit off where the second bearing sits.
08-22-2019, 07:47 AM | #26 | |
So, I took a brake cylinder hone and honed the inner portion of the outer bearing such that it does not have to be pressed onto the pinion - it will gently tap on with a brass hammer. This allows it to move back/forth such that the preload can correctly be set. I can see no reliable way to set the preload unless the pinion or a bearing is modified. Having to press on the outer bearing is a real problem (as it is currently manufactured). If I happened to have a precision crank grinder at home - would have done it that way! |
08-22-2019, 03:49 PM | #27 |
If you are using a repo R&P ,make sure you check the tooth contact.
Lawrie |
08-23-2019, 08:13 AM | #28 | |
John
Welcome each day |
