08-09-2020, 08:14 AM | #1 |
7-tooth steering worm sector bushings
Where may I get the correct tool to install (or remove) the 7-tooth steering worm sector bushings?...two of them.
I have talked to Snap-on about a "bushing installer/removal" tool, of which I have a few, and 1) they sent me the wrong tool after I told them exactly what I wanted plus, after talking to them once again, they tell me they do not have the correct size. On top of that, they still do not know what I want! The bushings are OD 1.252 and ID 1.125. Who else carries this item? Thanks. Pluck Last edited by Steve Plucker; 08-09-2020 at 08:20 AM. |
08-09-2020, 09:46 AM | #2 |
Re: 7-tooth steering worm sector bushings
If you or a friend have a metal lathe it shouldn't be hard to make something.
08-09-2020, 10:07 AM | #3 |
last one I did I used a hack saw to nearly cut through in 2 places near each other then used a cape chisel to peel out the piece, then the bushings fell out, then used a socket to push new bushings in, then on to the sunnen hone to fit the bushings
08-09-2020, 10:29 AM | #4 |
Pluck, sent you a private message.
08-09-2020, 07:07 PM | #5 |
