07-28-2020, 08:29 AM | #1 |
"8BA" Crank Pulley Car/Truck Inquiry
I had this post earlier:
https://www.fordbarn.com/forum/showt...91#post1899791 I have since discovered that the incorrect crank pulley nut was used (basically it would almost pass thru the bore of the pulley !) Currently I don't have a spare truck pulley but I do have a 52 Merc Car pulley, It appears the bolt & washer from the merc engine are what I need on the motor (they are all the same for that era it appears, obviously the Merc pulley is a narrow belt pulley, is the spacing the same from a 52 truck motor to a 52 car motor for example ? I assume the merc pulley will fit on my motor, wondering if I could just run narrow belts, but not sure if the car crank pulley belt grooves align to the truck water pumps, fan & genny, I don't think the wide truck pulleys will care if a narrow belt is running in them, but the offset is a whole other issue... The 52 pulley is an hour away from me right now so I thought I would do some pre investigation. |
07-28-2020, 08:57 AM | #2 |
Re: "8BA" Crank Pulley Car/Truck Inquiry
A v-belt grips by the sides of the belt. A narrow belt running in a wide pulley may be ok to “get you home” but I don’t think it’s gonna work for a long period. Should be plenty of those pulleys around.......Mark
07-28-2020, 10:24 AM | #3 |
Dennis if you can not find one locally I will pull one and send it to you! I am Roadster1927 on the hamb. Gary
I am usually relatively happy------Gary |
07-28-2020, 01:09 PM | #4 |
07-28-2020, 02:43 PM | #5 |
All pulleys need to be the same size to match.
08-17-2020, 08:55 AM | #6 |
