Old 01-30-2019, 08:29 AM   #1
1934
1934's Avatar
Default spark at the plugs
('37 FH motor)
When I short out the plugs with the motor at idle there are 4 cylinders that seem to be doing all the work and 4 that seem to be doing nothing. I.E. when I short out one of the 4 good ones the motor bogs down considerably and when I short one of the other 4 there is no difference in the idle. I thought it might be the plugs so I switched them up and no difference- always the same 4 cylinders not firing properly.
Does this sound like a timing issue or.... Any ideas appreciated.
Doug.
Sorry, just realized I meant to put this in the early V8 forum.
1934 is offline   Reply With Quote
Old 01-30-2019, 09:33 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: spark at the plugs
each side of carb does 4 cylinders, if idle passage on one barrel has a problem it can cause the problem you are describing
Old 01-30-2019, 09:36 AM   #3
Ray64
Ray64's Avatar
ditto what #2 said
Ray64 is offline   Reply With Quote
Old 01-30-2019, 10:00 AM   #4
1934
1934's Avatar
I don't think it's a fuel issue because there's 2 on each side not firing correctly.
Thanks guys.
Old 01-30-2019, 10:21 AM   #5
katy
katy's Avatar
Thanks guys.
IIRC, each barrel feeds 2 cylinders on each side, look closely at the intake manifold and you can see where the runners go.
Play it again Sam.
Old 01-30-2019, 10:41 AM   #6
burner31
burner31's Avatar
According to my calculations you have too many cylinders, discard the four that are inactive and retain the four that are firing.
File Type: jpeg 7bf20e311716c9f6f50cd81baf7a91e6_400x400.jpeg (18.1 KB, 7 views)
Keith
Shawnee OK
'31 SW 160-B
Old 01-30-2019, 11:11 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
I agree with burner31.
You don't need more than 4 cylinders as 4 is enough. If it was good Enough for Henry Ford then its Good enough for Me!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-30-2019, 11:27 AM   #8
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
HI 1934
How are your brakes and winshield wipers.If no good drop the pan.
veggie is offline   Reply With Quote
Old 01-30-2019, 11:30 AM   #9
Purdy Swoft
Purdy Swoft's Avatar
Be sure to remove the pistons and rods on the four dead cylinders to reduce the drag . I'm only kidding!!!
Old 01-30-2019, 12:51 PM   #10
40 Deluxe
Look for a plugged idle passage. One barrel of the carb feeds the middle two cylinders on one bank and the end two on the other bank while the other barrel feeds the remaining two end cylinders and two middle cylinders.
Old 01-30-2019, 02:54 PM   #11
1934
1934's Avatar
Some of you guys are a riot! Just imagine how much gas I'd save! LOL! Kidding aside, it sounds like a plugged idle passage as was suggested. On one bank it's the middle two cylinders and the other bank it's the two end cylinders not firing. Besides taking the intake off is there any other way to determine if that's really the problem?
Thanks for your help, (jokes and all), Doug.
Old 01-30-2019, 03:08 PM   #12
Jim/GA
Jim/GA's Avatar
Don't mess with the intake manifold. Just take the carb off, open it up, spray carb cleaner through all the passages, shake the excess cleaner out, put it back together and reinstall. Test drive.
The plugged idle passage is in the carb, if that's the problem, not in the intake manifold.
Jim Cannon
"Have a Model A day!"
Attention: MAFCA Members
* It's time to VOTE for your National Directors
* Please find your 2 ballots in your membership renewal materials that were just sent out
* Vote for Jim Cannon (me!)
* Return both ballots to MAFCA
* Thank you for your support!
Old 01-31-2019, 07:31 AM   #13
1934
1934's Avatar
Thanks for the advise. As soon as things warm up a bit here, (-3 F. in my unheated garage), I will try some carb cleaner.
Old 04-13-2019, 08:18 AM   #14
1934
1934's Avatar
I've posted an update on the early V8 forum just to keep things simple and not to have 2 threads going at the same time. I appreciate your help.
Doug.
