Old 03-28-2017, 02:44 PM   #321
Tinker
Tinker's Avatar
Default Re: 1941 Ford Pickup frame-off restore for the next generation
I did a Posies superslide reverse eye in the rear with standard sized shackles.
Probably took it down around 3-4 inches.
Before...
After... (I'm using a 7.00 tire all around)
Old 03-29-2017, 07:28 AM   #322
mrfliboy
mrfliboy's Avatar
Decided to try and lower it myself with what is available in my garage.
Homemade spring spreader to relieve some pressure, jackstands under frame, and jack on hub.
Was able to remove original (aftermarket) shackles with no trauma involved.
Local lumber yard 1_1/2" x 1/4" x 36" metal, cut in quarters and holes drilled, one side 1/2" for the sweg stud, other side 3/8" for threaded end. Used the original studs from the aftermarket shackles.
Raised rear end, slipped in new shackles, Start to finish under 4 hours.
Drove it a couple miles, rode perfect, with no noticeable sway, but I'll install a panhard this weekend, when I remove the wood floor.
Now that's the look I want.
mrfliboy is offline   Reply With Quote
Old 03-29-2017, 07:28 AM   #323
mrfliboy
mrfliboy's Avatar
Before...
Thanks for the pics.
Old 04-08-2017, 12:56 PM   #324
mrfliboy
mrfliboy's Avatar
Needed a new lawnmower, what better first use of the truck. Really running nice.
Old 04-08-2017, 01:15 PM   #325
JSeery
JSeery's Avatar
LOL, putting it to use!
Old 04-10-2017, 07:27 AM   #326
bfoley
bfoley's Avatar
The franken-box turned out really good! Did you have a floor or did you buy aftermarket?
bfoley is offline   Reply With Quote
Old 04-11-2017, 01:42 PM   #327
mrfliboy
mrfliboy's Avatar
For just this summer, I put in a 3/4" ply floor, $9.99 on clearance. Lol. I plan on putting some type of cover, canvas or a tonneau this summer, and than bodywork and paint over the winter.
Old 04-22-2017, 12:13 PM   #328
mrfliboy
mrfliboy's Avatar
Purists Look Away!
Needed away to haul my planes safely so ...
I finished up my Tonneau cover. Junkyard special, from Dodge Dakota 2001, stored on a rack in the weather. $40
Pressure washed and loaded up the tire dressing spray on it.
Cut down frame 14-1/2"
Weld tabs onto bed
Cut down canvas, have local upholsterer sew. $40
Hardly noticeable side profile....Priceless
Old 04-22-2017, 04:51 PM   #329
38bill
38bill's Avatar
FYI: Don't get rid of the old shackles. Those Posie springs will settle quite a bit. Over 15K miles I had to shorten the shackles on my truck to retain tire clearance three times and I am now down to about stock length.
38bill is offline   Reply With Quote
Old 04-11-2018, 08:40 AM   #330
FHFD
FHFD's Avatar
Great build, nice documentation..any updates?
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 04-13-2018, 11:15 AM   #331
mrfliboy
mrfliboy's Avatar
Thank you very much. Updates....... well it was either finish the bed, bodywork and paint, etc or fix the low end knock in my motor this winter.
Motor won. Will have full details when all finished. Its a whole story by itself. LOL
Old 04-13-2018, 11:48 AM   #332
VeryTangled
VeryTangled's Avatar
Hi Everyone. An RC Floatplane? Now THAT'S taking it to another level!
Now back to the story of what happened with the engine...
-Jeff
Old 04-14-2018, 09:07 AM   #333
mrfliboy
mrfliboy's Avatar
Good eye. Here's a shot from Minnesota.
Lots of fun, my other hobby for the past 25yrs.
Old 04-14-2018, 09:19 AM   #334
mrfliboy
mrfliboy's Avatar
About the motor let's just say I'm 6 months into it and it's still not done. Should have solid update when up and running in a month or so.
Old 04-14-2018, 10:55 AM   #335
Vintage Copper 47
Vintage Copper 47's Avatar
I would never "lower" a truck.. they are designed to carry loads.. and besides the cool factor; a lowered truck is harder to do repair work underneath.. JMO
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 04-24-2018, 02:59 PM   #336
mrfliboy
mrfliboy's Avatar
Wow Tough Crowd LOL
Old 05-05-2018, 06:51 PM   #337
mrfliboy
mrfliboy's Avatar
On to the next step,
Let's rebuild a motor. The fact I got to drive the truck the season was a bonus. I had a low end rod knock over 45mph. So kept it close by and waited to winter to rebuild.
Hoping for a quick fix and ends in full rebuild. 6 weeks takes 6 months.
Price well we all know how that turns out.
I'll let the pictures do the talking.
Phase 1 teardown:
Old 05-05-2018, 10:33 PM   #338
Tinker
Tinker's Avatar
Doh
File Type: jpg Screen Shot 2018-05-05 at 10.32.38 PM.jpg (7.1 KB, 4 views)
Old 05-06-2018, 07:46 AM   #339
mrfliboy
mrfliboy's Avatar
So what I found was a couple things. 2 quarter sized holes in the 2 rear cylinders, motor had already been punched out to 3.1875, 0.020 over.
Crank had rod journals turned over .030, and main journals were shot.
So block goes to machine shop, 2 sleeves installed and bored to .060.
I found a great crank from H&H Flatheads, main and rod bearings, I also had Mike recondition my rods.
All my other engine parts came from Van Pelt Sales. Great people to deal with.
Machine said 2-4 weeks and ends up being 6 months, I guess thats the way machine shops work. LOL
Old 05-06-2018, 08:04 AM   #340
mrfliboy
mrfliboy's Avatar
Finally engine assembly can begin. I have 4 different books to go by and all had something to help. Major one was Ol Rons floater bearings book and Mike's assembly book.
