10-05-2018, 11:49 AM | #1 |
Checking U joint
I have a sort of "tinny rattle" down by the shiftier. can't seem to locate the cause. Don't think it is heave enough to be a U joint but am wanting to check anyway. SO, what is the best way to check the U joint without pulling the torque tube and rear end?
10-05-2018, 12:43 PM | #2 |
Re: Checking U joint
Found the rattle, manifold heater was loose. However I would still like to know the best way to check U joint. Thanks
10-05-2018, 02:49 PM | #3 |
Once had a THUNK, on a quick take off, in Minerva. "Thought" it was the U-JOINT---It was my BIg Magnalite Flashlite, rolling around under the seat.
Bill W.
10-05-2018, 06:26 PM | #4 |
10-05-2018, 06:59 PM | #5 |
To check the u joint you could take the clam shell off which would give you some access to the u joint. With the transmittion in gear you might be able to rock the drive shaft enough to see if there is any play. I have not actually tried this but short of pulling the rear it may work. If your really suspecting the u joint I would pull the rear. Somewhat time consuming but not a bad job.
10-05-2018, 07:40 PM | #6 |
