Old 01-28-2020, 01:12 AM   #1
FlatheadEric
FlatheadEric's Avatar
Default Attn New Zealand Barners: 1941 Pickup Front Axle
A car friend of mine who does not use computers is working on a 1941 pickup that has been imported from USA, so Left Hand Drive.
It has had a lot of work done on it in the USA to make it into a 4 inch dropped front with disc brakes, chopped cab and a later model OHV V8 engine.
He wants to put the front back to standard height, or at minimum have a 2 inch drop (maybe to reduce road kill or just to void bottoming out all of the time). He wants to put it back to work rather than having a show pony.
Is there anyone in NZ that has a standard front end axle with stubs laying about suitable for the 1941 pickup Left Hand Drive?
I am not schooled in this equipment but understand that 1937 through to 1941 would do the job.
FlatheadEric is offline   Reply With Quote
Old 01-28-2020, 01:19 AM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Attn New Zealand Barners: 1941 Pickup Front Axle
Give Ajays a call they should be able to assist. also sometimes these come up for sale on Trade Me.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 01-28-2020, 01:32 AM   #3
FlatheadEric
Hello Phil,
I am working in Paeroa soon so will call into Ajays. There was a set on Trademe last week but it was RHD.
Old 01-28-2020, 06:48 AM   #4
51woodie
51woodie's Avatar
I may be out of my lane here, but looking at the front axle on my "46 Coupe the axle itself would be the same right or left. Looking in my "Green Book", the difference is with the spindles, base numbers 3105 and 3106 in the book. Could be wrong.
51woodie is offline   Reply With Quote
Old 01-28-2020, 08:33 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Hello Phil,
The AXLE itself doesn't know the difference between LHD or RHD. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-28-2020, 11:10 AM   #6
Brian
Brian's Avatar
As the stub axles have no doubt been modified to accept the disc brakes etc, why not just transfer them onto another stock axle?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-28-2020, 12:12 PM   #7
FlatheadEric
The axle looks reversable but the stubs (if that is the correct name) have the steering arms cast into them. The stub on the steering box side has only one hole for the tie rod between the two wheels but the stub on the opposite side has two holes, one for the tie rod and one for the steering rod back to the steering box. These are not reversable.
The cast steering arms on the stubs also look to be a dropped version to match the axle drop and allow the tie rod and steering rod to sit down at the level of the axle. If the axle is changed back to stock the stubs also need to be changed back to raise the steering gear as well.
Someone has machined adaptor plates to mount between the existing stubs and disc brakes.
This is why we are thinking that we need to source the LHD version of the front end parts.
Old 01-28-2020, 12:34 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Then what you want are a pair of '37-'40 LHD "roundback" spindles just like come on a '37-'40 passenger car. I didn't include 1941 roundback spindles because SOME 1941 passenger-side spindles have the drag link hole in the steering arm tapered from the top. You want BOTH holes (tie rod AND drag link) in that arm tapered such that the tie rod AND drag link attach to the BOTTOM of the arm. If the drag link hole is tapered from the top, the drag link will hit the bottom of the wishbone. Hope this helps.
Below is a link to a guy that just happened to have a pair of spindles for sale here on the 'Barn yesterday. Click the link! DD
https://www.fordbarn.com/forum/showthread.php?t=275934
T5 W/TORQUE TUBE
Old 01-28-2020, 12:41 PM   #9
FlatheadEric
Thanks V8Coopman, excellent information. I will pass on to the owner.
Old 01-28-2020, 02:03 PM   #10
my4dv8
You could get the shallow drop type bolt on steering arms . Of course that means cutting off the factory arms. You can also get a tie rod end with two holes , a hole for drag link and one for tie rod.
my4dv8 is offline   Reply With Quote
Old 01-28-2020, 09:21 PM   #11
Brian
Brian's Avatar
Correct; the steering arms were dropped to suit the axle...so, you 'undrop' them to suit the new axle. No need to buy replacements.
Old 01-29-2020, 12:25 AM   #12
cas3
Brian's got it right again as usual. bend em back to where you want. also, 42-48 spindles would work too if you have any laying around. same bolt pattern, same steering arms, same king pin size.
Old 01-29-2020, 06:37 AM   #13
V8COOPMAN
V8COOPMAN's Avatar
You should note that '42-'48 king pins ARE the same DIAMETER (making it possible to substitute on this axle), but of a different length. You always use king pins made for the year of the spindles, as the king pin LENGTHS vary accordingly. DD
T5 W/TORQUE TUBE
Old 01-30-2020, 01:38 AM   #14
FlatheadEric
Thanks for the information everyone, I have passed it all on to the computer hating owner.
So would the original arms have been heated and bent rather than being replaced the some after market dropped arms? Would heat and bend have been the usual method of modification when the drop axle was fitted?
Old 01-30-2020, 03:23 AM   #15
Brian
Brian's Avatar
Yes Eric, that is correct
Old 01-30-2020, 12:08 PM   #16
JSeery
JSeery's Avatar
Might research dropping spindle arms, but basically get the area you want to bend red hot and bend it. Allow it to cool slowly. They are normally bent in at least two ares.
Old 01-31-2020, 12:49 PM   #17
FlatheadEric
Great, that makes the undoing process much easier. Only have to change the axle back to standard and bend the steering arms to suit.
Job sorted - thanks everyone.
Old 02-03-2020, 06:35 PM   #18
kustoman
I think you will find that heating and bending steering arms is illegal in New Zealand.
Check on the LVVTA website.
kustoman is offline   Reply With Quote
Old 02-03-2020, 08:30 PM   #19
Brian
Brian's Avatar
Bureaucracy; Honestly, if they were put back to stock location, painted, how would anyone know?
Old 02-03-2020, 09:34 PM   #20
FlatheadTed
FlatheadTed's Avatar
Kustoman I am not surprised that this would be illegal in Nz since most of them making the rules for the rest of us don't know the difference between a drop forged part and a casting , In my USA 5' Shop book from the 40s specifies to bend the drop arm by heating it to centre the wheels ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
