01-26-2020, 07:18 PM | #1 |
39 accelerator pedal
My pedal keeps leaning to the right. I can push it back to straight up and down, but it eventually leans back over. Is there a clamp under or on firewall that can be tightened to maintain the rod in proper position?
Thanks - 30-9 1939, 1940 Last edited by 30-9; 01-26-2020 at 07:39 PM. |
01-26-2020, 07:51 PM | #2 |
Re: 39 accelerator pedal
Some pictures from my truck, hope this helps and may show something your missing or might be broken.
01-26-2020, 07:56 PM | #3 |
Thanks. I failed to mention my 39 is a deluxe coupe
Thanks - 30-9 1939, 1940 |
01-26-2020, 08:54 PM | #4 |
There is a raised rubber receptacle with a small hole into which the accellerator rod fits. Use dish soap to slip into position. The the base of the pedal bolts to the floor. A new pedal will solve your problem.
https://www.ebay.com/itm/1935-1947-F...%7CMake%3AFord |
01-26-2020, 09:01 PM | #5 | |
01-26-2020, 09:31 PM | #6 |
01-26-2020, 09:47 PM | #7 |
As said above, the hinge and attaching fastener keeps the pedal "square". The rod has pivots at each end and is not intended to hold it in place.
01-27-2020, 01:38 AM | #8 |
Probably hinge at base of pedal that is worn
01-27-2020, 06:35 AM | #9 |
Ok thanks, I’ll check hinge
01-27-2020, 06:59 AM | #10 |
01-27-2020, 08:07 AM | #11 |
Guys, guys, guys... authentic (read: CORRECT) pedals have two ends bent over on the metal plate that is ultimately bolted to the floor board. When the pedal is fastened to the wooden floor board, the ends are driven in to the wood. Thus, the pedal can't rotate.
Repop pedals do not have this feature. Of course, it would be easy enough to modify a repop pedal.
01-27-2020, 09:03 AM | #12 |
If possible please post a photo of an original pedal showing how it fastens to the floor.
I just can't recall how mine was before I replaced it. Thanks. |
01-27-2020, 11:58 AM | #13 |
I don't have a photo of what you are seeking. There's a staked nut within the wood floor board. One bolt with lock washer goes through the pedal "hinge" and in to the staked nut. That holds the pedal TO the floor board. The two bent corners of the pedal "hinge" are what keeps the pedal from pivoting.
Thread Tools | |
Display Modes | |
