11-20-2019, 08:52 PM | #1 |
33 engine noise
Our 33 has an engine noise(not a mechanical noise), its a harmonic sort of a droning.
Its related to how much throttle I have on and as soon as I lift off a bit its gone,Its also worse when the eng is cold and a lot quieter when the engine is fully warmed up. I have lined the floor and firewall with dynamat , this made it better inside the cabin, the exhaust is a single system and a small stainless muffler that is about 6 inches in diameter and a foot or so long,it has always been on. the exhaust is not touching the chassis anywhere. IDEAS ?? Lawrie |
11-20-2019, 09:31 PM | #2 |
Re: 33 engine noise
Clueless without seeing-hearing it . That said try taking the fan belt off and make a QUICK drive .
Did you check for u-joint slop ?? Last edited by David J; 11-20-2019 at 09:45 PM. |
11-20-2019, 10:00 PM | #3 |
Re: 33 engine noise
load orientated ... bearing in the driveline somewhere? I noticed mine doing a similar thing the other day quite a loud humming -drone noise, normally I have the radio on so dont notice it so much. Turn you radio up or get Carol to sing louder..?
11-20-2019, 10:13 PM | #4 |
Re: 33 engine noise
Thanks Rob
David J new U/joint , no vib or noise from there, Fan belt ,it would not know if the power was on or off you would think. Lawrie |
11-21-2019, 12:02 AM | #5 |
Re: 33 engine noise
I once traced a harmonic noise (low buzz) that was RPM sensitive to a loose baffle in the muffler. Drove me crazy until I isolated it.
11-21-2019, 12:07 AM | #6 |
Re: 33 engine noise
11-21-2019, 12:51 AM | #7 |
Re: 33 engine noise
Ted, I went to the muffler shop today and maybe will look at fitting a bigger newer muffler, shame as the whole system is stainless and fits up realy nice.
Lawrie |
11-21-2019, 02:31 AM | #8 |
Re: 33 engine noise
Agree ,
For the amount of things it would positively eliminate and a relatively simple task I would still try it . Your call . You can hear other things better also with the belt off . |
11-21-2019, 03:54 AM | #9 |
Re: 33 engine noise
OK David point taken ,I will drop the belt off tomorrow and do a short run.
Thanks Lawrie |
11-21-2019, 05:15 AM | #10 |
Re: 33 engine noise
Longshot at best but what if ?
Good Luck Bud . David J |
11-21-2019, 01:56 PM | #11 |
Re: 33 engine noise
Is the noise present, when the car isn't moving? If so, it eliminates any drive train issue and you can probably find it with a stethoscope.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
11-21-2019, 07:32 PM | #12 |
Re: 33 engine noise
Don’t rule out the front main drive bearing in the transmission .
11-21-2019, 07:32 PM | #13 |
Re: 33 engine noise
Had similar noise in a 34 Ford once.
11-21-2019, 07:43 PM | #14 |
Re: 33 engine noise
I like flathead V8's but I've never owned one and don't know how they are mounted on the frame, or if they used rubber in the mounts. Is it possible the rubber has gotten hard or worn, and the engine could transfer more vibration through the frame and cause a harmonic/droning sound ?
Sal |
Thread Tools | |
Display Modes | |
