Old 04-10-2019, 01:59 PM   #1
runmikeyrun
Default Making your own vinyl/rubber floor?
Looking to cover up an unsightly part of our truck’s floor that covered in overspray (outlined in white). Has anyone custom cut any rubber or vinyl product for something like this? The pre-cut stuff is expensive and I’m not sure it will fit ok.
Vehicle is an open cab ‘42 body style fire truck.
Thanks in advance.
runmikeyrun is offline   Reply With Quote
Old 04-10-2019, 02:34 PM   #2
41ford1
41ford1's Avatar
Default Re: Making your own vinyl/rubber floor?
Both Homedepot an Lowes have black rubber floor matting in rolls. The stuff is about 1/16" thick. I believe the roll was 48" wide. It was sold by the linear foot.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 04-10-2019, 05:28 PM   #3
Blastfromthepast
try a company called Rubber Cal Google it, Has everything you need
Blastfromthepast is offline   Reply With Quote
Old 04-10-2019, 05:29 PM   #4
runmikeyrun
Thanks guys! What the best way to secure it? I was thinking self tapping sheet metal screws and a washer.
Old 04-10-2019, 06:11 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
>>>self tapping sheet metal screws and a washer.>>>>
No!!!! I'd brush flat black or sanded paint on it if it's just for aesthetics. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 04-10-2019, 06:19 PM   #6
Willit Stop
Willit Stop's Avatar
Most parts houses carry a bed liner material that is applied with a small roller.An old sweat sock will work too. Use the fuzzy side and dab it on to create a texture.
Willit Stop is offline   Reply With Quote
Old 04-10-2019, 06:23 PM   #7
runmikeyrun
I like that idea. We have some in a spray can already but I hate spray painting something like that. Thanks!
Old 04-10-2019, 08:15 PM   #8
Zax40
Zax40's Avatar
I've used a roll on bed liner in floor boards before on my old Jeep. Works great as long as the floors are roughed up a little and then cleaned really well. Don't get that bed liner stuff on your hands though. It does not come off.
Zax40 is offline   Reply With Quote
Old 04-10-2019, 09:20 PM   #9
Tinker
Tinker's Avatar
If you get a thicker type rubber mat it shouldn't really be an issue moving around, but a good idea. Weight will keep it in place. Probably could try some 3m double sided trim tape also.
As a side note... I believe dennis carpenter sells a very nice mat for the the 40s cabs. What I have in my 38. Not as cost efficient as a rubber slab and may take a bit of time for delivery. But they are super nice mats with all the right molded designs.
Certainly if you get a thicker rubber material it'll work very nicely without added grip.
https://www.walmart.com/ip/Weider-36...b7&athena=true
This stuff is a little thin but maybe they offer thicker stuff....
https://www.ebay.com/itm/Black-Anti-...-/391340287086
Old 04-12-2019, 12:53 AM   #10
runmikeyrun
I did some measuring and pondering today. I think the bed liner will work best. There are some more expensive ones that you can tint but for now I think I will use the Herculiner red (provided I can find it).
Thanks! I’ll post pics how it turns out.
Old 04-12-2019, 07:37 AM   #11
Zax40
Zax40's Avatar
Be aware Herculiner is very coarse. It's like coating your floor with a grinding disk.
Old 04-12-2019, 10:12 AM   #12
Willit Stop
You may want to scuff off any loose paint or over spray.The bedliner will only stick as good as what's under it. Good luck.
Old 04-12-2019, 11:30 AM   #13
cas3
you will have a hard time cleaning the floor when its grinder disk-like surface i would guess. i would rather a loose rubber mat you can remove and sweep it out. just my thoughts.
Old 04-12-2019, 08:12 PM   #14
runmikeyrun
I was at the hardware store today and for $12 I was able to get some vinyl mat off a roll. I’m most of the way though installing it, I will post a pic later.
The permanence of the truck bed coating is what stopped me. I decided to clean it up a bit until I can get a color matched spray to repaint the floor. I’m trying to keep our truck as true to its form as possible yet still look good.
