Old 09-11-2019, 08:08 AM   #381
Shoebox
Shoebox's Avatar
Default Re: New block
I like many others here have anxiously followed this thread, and am very appreciative of the time Tod has invested. I do have to ask, and correct me if I am wrong, but has it not been years since we last heard from Tod??
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 09-11-2019, 08:21 AM   #382
Yoyodyne
Yoyodyne's Avatar
Tod hasn't disappeared. He's still busily working on and making Model A and B parts.
Yoyodyne is offline   Reply With Quote
Old 09-11-2019, 09:14 AM   #383
Shoebox
Shoebox's Avatar
Certainly good to hear, and not surprised that he is busy. However I was speaking to any word on the flathead V8 project.
32 Ford roadster
39 Mercury Towncar
Old 09-11-2019, 09:19 AM   #384
JSeery
JSeery's Avatar
Tod posted on 30 Aug: https://www.fordbarn.com/forum/showthread.php?t=268692
Old 09-11-2019, 09:34 AM   #385
tubman
tubman's Avatar
It sure looks like his plate is full. IIRC, he makes some special castings for late model Fords as well. Talented (and busy) guy.
Old 09-11-2019, 10:05 AM   #386
Shoebox
Shoebox's Avatar
Full plate, busy guy absolutely! But apparently no flathead V8 info since 2017, but if I missed something, gosh let me know.
32 Ford roadster
39 Mercury Towncar
Old 09-11-2019, 11:30 AM   #387
philipswanson
Originally Posted by tubman View Post
Did you read the post "B&S" made about his "NOS" 59A block? A lot of "NOS" parts were factory rejects with the attendant problems.
Unless you have had your blocks thoroughly tested, I'll bet at least 8 of them are bad.. "Ran when parked" is not good enough; when I was in college, I ran an 8BA with 7 cracks between the valve pockets and the cylinders for two straight years with a combination of "STP", "Barr's Leaks", and some luck. I sold my second to last "good" 8BA block to a guy who had gone through 5 blocks from used engines that turned out to be unusable.
You are correct that there will be some good blocks coming out of the "woodwork" over the next 20 years, but nowhere near enough to satisfy the demand that seems to be building now. In addition, "Tod" is planning some modifications that will make his new blocks superior to anything used. They probably won't be "legal" for Bonneville and SCTA competition (at least not for a while), but they will be a boon for the average "hotrodder".
The NOS is a wartime military engine in cosmolene since new, not a reject. The others are low mileage original engine that were all visually checked. I'll probably never use any of them since I have 3 good running cars that I almost never drive.
philipswanson is offline   Reply With Quote
