08-29-2018, 10:02 AM | #1 |
Strange Transmission Modification
I've been in the process of moving and going through my old car stuff. I had this spare transmission and was looking it over to see if it was worth a hoot and noticed the strange large gear welded on to the input shaft. A corresponding small gear is welded to the cluster gear. Any idea why?
"whatever works!" |
08-29-2018, 10:16 AM | #2 |
Re: Strange Transmission Modification
Overdrive
08-29-2018, 10:48 AM | #3 |
Following this. I have never heard of this before.
08-29-2018, 10:56 AM | #4 |
When you shift gears what is the action of the output shaft?
08-29-2018, 11:01 AM | #5 |
I know it's hard to see, but notice the center of the cluster has been machined off.
"whatever works!" |
08-29-2018, 11:03 AM | #6 |
I don't see a cluster gear at least not a whole one. Bob |
08-29-2018, 11:04 AM | #7 |
It appears that the only functions are straight through like normal third gear, and reverse engaged and not engaged. And reverse is either 1 to 1 or very close.
"whatever works!" |
08-29-2018, 11:05 AM | #8 |
The boat idea makes some sense.
"whatever works!" |
08-29-2018, 08:05 PM | #9 |
it looks like it was made to run at a high speed in reverse and direct drive forward. they have machined off low and second gears off the cluster gears. I will go with a boat.
08-30-2018, 09:48 AM | #10 |
Strange, but using it to operate a boat or winch does seem to make sense. Still, for a boat or winch, I'd have used a stock tranny.
08-30-2018, 10:18 AM | #11 |
Unfortunately, I can't see much of a reason to keep this in my "collection". Can't see much of any use for anything...
"whatever works!" |
08-30-2018, 11:18 AM | #12 |
There are some good parts to be saved. Don't throw it away, but pass it to someone that would use or save the good parts.
08-30-2018, 11:19 AM | #13 |
Save or sell the good parts.
