08-29-2016, 02:29 PM | #1 |
My 59ab starts cold but fails hot ?
I have not had any problems with my 37 pickup for years and still will start on the first turn over when it is cold but after I drive it for a half hour and turn it off it will not attempt to start. Let it sit for an hour and it starts standing on the ground and hitting the start button. I am now pulling the crab distributor and cleaning the points and rotor. Need to know what the points settings for a 59ab Crab distributor and the odds that I need a new 12 volt coil & Condenser ??? tia
~~Walts37~~ |
08-29-2016, 02:40 PM | #2 | |
Re: My 59ab starts cold but fails hot ?
Keep me posted on what you find and I'll do same.
Thanks - 30-9 1939, 1940 |
08-29-2016, 02:44 PM | #3 |
Will do I did find the point setting in one of my books looks to be .012 - .014 gonna try that now.
08-29-2016, 02:58 PM | #4 |
You didn't say how it cranks when hot. Often on 6 volt systems the starter drags enough when hot and expanded that it draws too much amperage and doesn't leave enough voltage to fire the points.
Long story but when I was a kid my dad had an old 6 volt pickup that did that. One day we were at the blacksmith's and it wouldn't start. The old blacksmith said "I can fix that" He pulled the starter, put the armature in his lathe and shaved it down a little, put it back together and the old truck started fine hot ever after. Just bad starter bushings can let the starter drag enough too. |
08-29-2016, 03:13 PM | #5 |
Walt, my motor manual says .015 for the points, engine not starting hot is usually caused by two things, one is that after the engine warms up it gets the intake manifold hot and boils the gas out of the float chamber into the engine causing it to flood, next time you shut the motor off with a flash light look down the throat of the carb to see if any fuel is dribbling down the carb throat, if so there is a couple of things you can do to help stop that, aluminum manifolds pass more heat to the carb than cast iron, use a 1" or so phenolic carb under carb, block off the carb heater passage in the intake manifold that is under the carb just behind the carb, check the coil, if you cant put your hand on it and leave it there with out burning your hand I would say the coil is failing, letting the car set for an hour or so lets the gas evaporate out of the engine and the coil cool down thus letting the engine start
08-29-2016, 03:23 PM | #6 |
08-29-2016, 04:15 PM | #7 | |
Thanks for the input I will post the outcome with good results I hope lol. |
08-29-2016, 04:26 PM | #8 | |
Thanks again ~~Walts37~~ |
08-29-2016, 04:31 PM | #9 |
What is the resistance of the coil? Needs to be at least 3.0 ohms.
08-29-2016, 04:55 PM | #10 | |
Thanks for the input. I did live in Wichita for about 15 years back in the 60s & 70s Worked at Beech and owned a CB shop on south Broadway called Smokey's Electronics. ~~Walts37~~ |
08-29-2016, 04:59 PM | #11 | |
You want the primary to be at least 3.0 ohms, the diagram is for a coil with a ballast resistor. If you decide to replace the coil I would suggest you read Bubbas suggestions before you pick one. Last edited by JSeery; 08-29-2016 at 05:58 PM. |
08-29-2016, 05:52 PM | #12 | |
Thanks again for all the help. ~~Walts37~~ |
08-29-2016, 06:49 PM | #13 |
JSeery. Do you check the coil like in the pic with the coil on the bench or with the wires on the car hooked up? If you have 1/2 dox coils under the bench and don't know if they are 6 volts or 12 volt coils, How do you check em? Thanks Walt
08-31-2016, 11:05 AM | #14 |
[B]I would like to thank all who came to my aid on this problem. The starting problem seems to be resolved but still running a little rough when above idle. I did pull the plugs look good & ordered a new coil from JC Whitney & a set of points from Dennis Carpenter in hopes the roughness goes away when they get here. also replaced a frayed coil wire but still running a little rough. Thanks again for all the suggestions.
~~Walts37~~[/B] |
08-31-2016, 11:18 AM | #15 |
This is just an idea of course, you can get an original Ford coil rebuilt by Skip Haney set up for 12 volt negative ground and use and external resistor. That may prove more reliable than the JC Whitney coil. Just a thought.
08-31-2016, 12:04 PM | #16 |
We had the same thing with the '36 pickup with a 59AB. I tried all the obvious stuff, changed coils, condensors, checked plugs, points,etc. Usually these problems are electrical don't condemn the carb, right
Sent the Distributor to Bubba over in Indiana, he found worn bushings, rebuilt the dist (did a super job) popped it in same thing. Coil checked out OK. Did a compression check it was fine. Next started fooling with the fuel side. Worn fuel pump? Sent that out to Charlie and he rebuilt my original fuel pump. No difference still a problem. Drained the gas tank and added non-ethanol fuel from Phillips 66. No change. Sent the Stromberg97 to another guy I won't mention for a rebuild. Got it back still a problem, and the carb didn't seem 'right' the choke bound REAL bad and several other issues. Truck lacked power. Even harder to start now. You had to pull out the choke HARD it was not smooth at all. I called the guy up and he said 'Just oil it'. In 40 plus years of fooling with carbureted Fords I had never been told or heard of 'oiling it.' Hmmmmmm. Sent the carb to ANOTHER guy and he went thru it and found a lot of issues. Throttle plates mis-aligned. Jets were too big for the carb. Float set wrong. Choke was 'bent'. The bore for the choke was out of round (I don't know what he did to it at least I got an original Stromberg back might have been somebody elses. Luckily it wasn't one of the infamous JUNK Chinese knock offs that are floating around.) Carb had some junk rebuild parts the first guy used (still was charged $200 for a bad job from rebuilder at door #1 Let's Make A Deal. The second rebuilder dialed it in ran it on a flathead and shipped it back. Plug and Play time. NOW the truck starts right off hot or cold and runs better than it ever has. The sweet spot now is, cold start you set the choke just a tad, pump it once maybe twice, hit the starter and she fires on the second revolution. Hot use no choke hit the starter and starts right off first time. Good luck hope this helps. |
08-31-2016, 12:12 PM | #17 |
You are probably right on the Skip Coil but I am replacing a Whitney coil that has been perfect for 10 years and may still be good. The one I am replacing had vibrated down in the bracket and was siting right on the head for some extra heat so replacing it is just a thought. I hope it helps with the roughness if not I guess I will have a spare coil sitting around. lol
08-31-2016, 12:14 PM | #18 | |
08-31-2016, 12:23 PM | #19 | |
~~Walts37~~ |
08-31-2016, 02:38 PM | #20 | |
On a stack of coils, the ohms reading are going to give you a general idea of what type of coil it is. An ~1.5 to 3.0 ohm coil is most likely a 12 volt coil while one in the <1.5 ohm range probably a 6 volt coil. But, there are going to be exceptions. Coils with the lower ohms ratings can be high performance 12 volt coils. This applies to points type coils, electronic ignitions will have totally different values. For 12 volt coils: 1- 1.5 ohm coil= contact ignition system and some electronic ignitions 2- .5 ohm coil needed for current controlling electronic systems like the GM HEI ignitions. 3- 3-4 ohm coil used with no ballast systems as the ignition coil has it built in. Used mainly in fours and sixes as the dwell time is longer on these units and coil saturation is better. Last edited by JSeery; 08-31-2016 at 02:43 PM. |
