01-11-2014, 06:09 PM | #1 |
PVC Valve
Is there a PVC valve that is best suited for a 239 flathead engine? Thanks and God Bless, Selmer
01-11-2014, 09:58 PM | #2 |
Re: PVC Valve
not sure if best suited, but maybe the PCV valve from the Jeep 258 engine??....good luck....Mike
01-11-2014, 10:00 PM | #3 |
Re: PVC Valve
10/4!
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
01-11-2014, 10:43 PM | #4 |
Re: PVC Valve
I used a Fram PCV306. Works great.
01-12-2014, 12:20 PM | #5 |
Re: PVC Valve
Make sure the vacuum hose with the PCV in it is below the throttle valve plate. Eliminate the road draft tube, using a fitting in it's place to connect the vacuum/PCV hose. Make sure that you have a vented cap on the oil fill tube... The 8BA and 8CM engines are very simple, compared to the early engines to utilize a PCV on...
Bill.... 36 5 win cpe |
