02-23-2015, 08:46 AM | #1 |
rear end change
Morning guys.....while going through the rear brake's on the roadster. I discovered that the linings were completely gone....the grease seals are leaking and everything should be completely disassembled and cleaned and rebuilt.. My question is....I have another rear end that I bought from a reputable guy that has been rebuilt and has new brakes on it.the radius rods are on it and the have been blasted and powder coated.....would it be easier to change the rear end rather than disassembling the old one and replacing the brakes? I will also add that the drive shaft and torgue tube are still attached to the new rear end and that I would most likely use those as well. Can I install the rearend and dirive shaft as on unit.
Thanks e everyone. Last edited by rob63mess; 02-23-2015 at 08:50 AM. Reason: spelling |
02-23-2015, 09:29 AM | #2 |
Re: rear end change
Yes you can install as a unit. You will need a spring spreader as the rear spring is under tension and can be dangerous.You can take spring out with the axle assembly or leave it on the car. Roll the old axle out on a floor jack and roll the new one in.
John |
02-23-2015, 09:31 AM | #3 |
Re: rear end change
R&R the complete rear end is much quicker and easier than rebuilding what you have.
02-23-2015, 09:54 AM | #4 |
Re: rear end change
thanks guys...I thought that was going to be the answer. Where do I get the spreader...is it something I fabricate or buy from a vender?
02-23-2015, 10:26 AM | #5 |
Re: rear end change
I bought this one on eBay:
02-23-2015, 10:26 AM | #6 |
Re: rear end change
02-23-2015, 11:55 AM | #7 |
Re: rear end change
If you have a local Model A club, they may have one in their "tool chest".
02-23-2015, 11:56 AM | #8 |
Re: rear end change
Fred....I wish I had a club near me.
02-23-2015, 01:29 PM | #9 |
Re: rear end change
Check the rear end ratio on the new rear end before you install it and be sure it is something you will like.
Charlie Stephens |
02-23-2015, 01:40 PM | #10 |
Re: rear end change
Thanks charlie.
02-23-2015, 01:43 PM | #11 |
Re: rear end change
Just got off the phone with Don at Snyders.....ordered a new spreader. Better have the right tool for the job.
02-23-2015, 01:48 PM | #12 |
Re: rear end change
Owning a Model A is really just an excuse to buy more tools!
02-23-2015, 04:12 PM | #13 |
Re: rear end change
include pics for usn's that are going to do the same job,when/if it warms up...thanks kev
02-23-2015, 07:24 PM | #14 |
Re: rear end change
I will Kevin....I just got an email and the spring spreader is backordered a week or two. I'll post pics when we do the job. I'd be willing to loan the spreader when I'm done with it.
07-03-2017, 11:55 PM | #15 |
Re: rear end change
Hello guys, working on my 32 Pickup, removed rear end, replaced the shackle bushings, now ready to install rear end. I put shackles plates on passenger side rolled over to the drive side, and have a 3-4 inch between spring eye and housing? Is this where the Leaf Spring Spreader comes in handy?
Frank |
07-04-2017, 02:13 AM | #16 |
Re: rear end change
You will find a small note included with your new spreader that say's, "grease spreader prior to use!" Be sure and remember to do it, it will make the job a breeze. These spreaders work great and are built with safety in mind. Have fun with your "A!"
They know enough who know to learn. |
07-04-2017, 06:55 AM | #17 | |
Re: rear end change
