02-14-2020, 03:06 PM | #1 |
64 Galaxie adding sound deadening material
Just removed compete interior of car and of course taking care of some rust issues. Now need to sound deaden the floor pan which is quite large nearly 40 sq ft. Any recommendations that won't break the bank.
02-14-2020, 09:17 PM | #2 |
Re: 64 Galaxie adding sound deadening material
Spray on bed liner??
02-15-2020, 12:14 AM | #3 |
Go over to the HAMB and search "peel and seal". You don't need to be a member. You'll find whole threads on a variety of products, effects, etc. Peel and seal is a roof patching product from a big box hardware store. All worth a look.
They talk about stopping drumming, foil for heat, etc. I've used a variety of products over the years, mostly commercial, from lead impregnated rubber in motor homes, to rubber insulation for industrial tanks. Whatever you use, a good roller for Formica work really helps lay it down. Having done Formica work in the old days I had the rollers. After that I use cheap foam, then carpet. Makes an amazing difference in sound and heat. Last edited by miker98038; 02-15-2020 at 12:21 AM. |
02-16-2020, 02:11 PM | #4 | |
Thanks for that great info. I'm going to be redoing my '65 Thunderbird interior, and the factory replica sound insulation from Mac's will cost hundreds of dollars, and that's not including the jute underlay for the carpet. |
02-15-2020, 08:27 AM | #5 |
When laying down any of the peal and stick stuff use a heat gun to warm it up. Doing that really makes it stick down well. I have used a mastic from McMaster Carr, put down with a roller and the heat gun followed with sticky duct insulation from Lowes and aluminum tap to seal it all up..
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
02-15-2020, 12:50 PM | #6 |
02-19-2020, 12:59 PM | #7 |
I used Fat Mat on my floor, 1/2 the price of Dyna Mat and easy to work with.
02-19-2020, 01:09 PM | #8 |
I used EZ Cool on the roof, the vertical panels, firewall, and floor.
check this out: https://www.hotrodreverend.com/post/...oor-insulation there are more articles on the site but the above is the one on the floor of course
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
02-19-2020, 05:11 PM | #9 |
Great feedback guys, Can't miss with you help, thanks Rob
02-20-2020, 11:55 PM | #10 |
Fat mat or dynamat work great. Also 1/2" jute auto carpet underlay really cuts sound down
