Old 10-19-2020, 12:51 PM   #1
farmerdick
farmerdick's Avatar
Default Ford Starter Rebuild
I am doing a rebuild of a ford starter and have removed the 2 brushes that are held on by screws. Now the other 2 are crimped on by heavy duty tabs. What is the best way to bend these tabs back to remove the brushes? They are are quite "stiff". I have tried several times to bend them back, trying not to disrupt where they go back into the starter winding's. Thank you.
farmerdick is offline   Reply With Quote
Old 10-19-2020, 02:04 PM   #2
WABOOM
WABOOM's Avatar
Default Re: Ford Starter Rebuild
Those are soldered.
WABOOM is offline   Reply With Quote
Old 10-19-2020, 03:26 PM   #3
flathead48
They are soldered in and you will to solder in the replacement ones.
flathead48 is offline   Reply With Quote
