01-25-2020, 02:32 PM | #1 |
Horn Power
I just installed a new horn / light switch rod in my steering column. Lights - parking, low beam, and high beam are A oK. l don’t have any current to the horn. I’m not sure what to look for.
01-25-2020, 02:45 PM | #2 |
Re: Horn Power
The power goes from the cutout straight to the horn, the ground goes
from the horn button through the light switch to the horn. Bob |
01-26-2020, 11:17 AM | #3 |
Re: Horn Power
As Bob said, take a voltmeter check your wires at the horn you should have a hot to ground on the engine and then if you Push the horn button you should have a ground on the other wire
01-30-2020, 09:03 PM | #4 |
Re: Horn Power
Searching the circuits out and refusing to the proper wiring diagram l did locate the problem.
Someone cut off the pos. wire and tucked it back into the sheathing feeding the horn. Now I need to rebuild the existing horn. |
01-30-2020, 11:40 PM | #5 |
Re: Horn Power
Now your enjoying your car and having fun. Nothing like finding and fixing an electrical problem
01-31-2020, 12:39 AM | #6 |
Re: Horn Power
Chris W. |
01-31-2020, 09:09 AM | #7 |
Re: Horn Power
02-01-2020, 11:15 PM | #8 |
Re: Horn Power
I agree with tha but it's a pity they aren't as loud as other similar horns on other cars. There is quite a difference between the Model A horn and the ones on Chrysler cars for example.
02-02-2020, 10:49 PM | #9 |
Re: Horn Power
Oh so true. My '25 dodge brothers has a Northeast Co. Aooogah horn and out does my '31 Ford Spartan.
