Old 01-25-2020, 07:03 AM   #1
Jembow
Jembow's Avatar
Default helmet distributor air gap?
I'm sure I read a recent post saying the rotor to side plate gap is crucial to good starting and running. Question is, what should that gap be? I'm assuming close as you can make it without touching. Is there a recommended max & min?
Jembow is offline   Reply With Quote
Old 01-25-2020, 01:32 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: helmet distributor air gap?
48-12201: Max 0.0105", Min.0.0035"
Old 01-25-2020, 02:36 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
In a 30s radio installation book it said ( for reasons of radio interference), build up or move contacts to get 0.005 gap
A larger gap increases firing voltage for the spark plugs, a larger rotor gap will fire fouled plugs because of the higher voltage needed to jump the rotor gap---- but too much gap can increase the voltage beyond what the coil can make--- or stress the insulation to failure in the coil
Old 01-25-2020, 05:18 PM   #4
Jembow
Jembow's Avatar
Thanks gents
Thread Tools
Display Modes
