Old 01-04-2020, 10:50 AM   #1
skidmarks
skidmarks's Avatar
Default 33 34 big truck fenders on 32 pick up
Does the 33 34 big truck front fenders have the raised area at the front crossmember like the pick up fender?
Is the contour along the top of the frame rail the same as a 32 car chassis?
skidmarks is offline   Reply With Quote
Old 01-04-2020, 11:15 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 33 34 big truck fenders on 32 pick up
Yes and interchange with the pickup.Don't know about the contour but they won't work on a '32 frame.
deuce lover is offline   Reply With Quote
Old 01-04-2020, 11:52 AM   #3
deuce_roadster
deuce_roadster's Avatar
What deuce lover said x2. Many have tried to make those fit on a 32 frame and there is a lot more to it then just taking out the raised area over the rivets. They won't work on a 32 but will on a 33-4 pickup just fine.
Old 01-04-2020, 12:05 PM   #4
DavidG
DavidG's Avatar
The list of differences between '32 front fenders and '33-'34 pickup/big truck fenders is almost endless from the contour of the frame to the attachment to the frame to the attachment to the running boards. Since '32 front fenders are the same for all '32s including commercial vehicles and big trucks (except big trucks with side-mounted spares), they are not that scarce.
Old 01-04-2020, 03:47 PM   #5
skidmarks
skidmarks's Avatar
It was going to be used on a fenderless hotrod pickup to make it full fendered and they were cheap and local. But with that much difference, will probably end up just buying a new pair from brookville.
