Old 06-17-2019, 08:12 AM   #1
Zax40
Default Fuel pump stand with small pinholes usable?
My fuel pump stand has some pitting and a few tiny pin holes in the steel tube that goes down into the intake. It was lightly media blasted. The metal is still solid, but will the small holes be a problem? Could it lead to excessive smoke out of the breather? Should I just start looking for another in better shape?
Application is a 221 in a '40.
Zax40 is offline   Reply With Quote
Old 06-17-2019, 08:22 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Fuel pump stand with small pinholes usable?
Fill them with solder to ease your worries.
Old 06-17-2019, 08:47 AM   #3
RalphG
RalphG's Avatar
JB weld is an amazing product for filling small holes like that. I've patched gas tanks with it.
RalphG is offline   Reply With Quote
Old 06-17-2019, 08:51 AM   #4
Zax40
I thought about that, but didn't know how it would hold up to the heat inside the engine.
Old 06-17-2019, 08:56 AM   #5
34PKUP
34PKUP's Avatar
Solder will.
34PKUP is offline   Reply With Quote
Old 06-17-2019, 09:22 AM   #6
philipswanson
JB will hold up fine too in engine temperatures. Solder might not stick on pot metal unless you have the right rod. JB will be a permanent repair. Make sure you clean it, especially in the holes. Pack it in, then smooth the surface. It will be fine.
Phil Swanson
philipswanson is online now   Reply With Quote
Old 06-17-2019, 09:22 AM   #7
Automotive Stud
Automotive Stud's Avatar
That's an odd spot to rust since it's usually covered in blowby. I'd just look for a better one, that should be easy enough to come by a better one.
Automotive Stud is offline   Reply With Quote
Old 06-17-2019, 09:26 AM   #8
tubman
tubman's Avatar
I think I saw one on the shelf yesterday that I don't need. If interested, send me the particulars, and if it's the right one, it's yours for shipping. It should fit in a small flat rate box for $7.60 (if you're in the U.S.).
tubman is online now   Reply With Quote
Old 06-17-2019, 09:30 AM   #9
36rgtop
36rgtop's Avatar
Phil Swanson
Since when is a "steel tube" pot metal?
36rgtop is offline   Reply With Quote
Old 06-17-2019, 10:53 AM   #10
Zax40
That would be fantastic! It's right at 4 3/4 from the base where it bolts to the intake to the top of the tube where the breather goes. Looks like the one in the link below.
https://picclick.com/Vintage-Ford-Fl...757681644.html
Old 06-17-2019, 11:04 AM   #11
deuce_roadster
deuce_roadster's Avatar
If nobody closer gives you one I have several, you can certainly have one. PM me if need be.
Old 06-17-2019, 05:45 PM   #12
tubman
tubman's Avatar
I just measured mine and it is about 3" from the base to the top, so it won't work. Sorry. Too bad; it looks NOS. After looking at it, I don'r see why you just couldn't replace the steel tube with a piece of the proper size. It looks like it's just lightly pressed in.
Old 06-17-2019, 08:33 PM   #13
tubman
tubman's Avatar
I just looked at the picture you supplied and I think maybe mine might be the right one after all. Like I said, it appears to be NOS (or maybe a repop) and the top large sheet metal tube is not installed on mine. Measure the pot metal part of yours and if it's 3", we may have a winner. I don't know how much effort it would take to remove the top large tube from yours, but it might be worth trying.
Old 06-18-2019, 08:29 AM   #14
Zax40
I just looked at the picture you supplied and I think maybe mine might be the right one after all. Like I said, it appears to be NOS (or maybe a repop) and he top large sheet metal tube is not installed on mine. Measure the pot metal part of yours and if it's 3", we may have a winner. I don't know how much effort it would take to remove the top large tube from yours, but it might be worth trying.
Thanks, i'll measure it today when I get home from work.
Old 06-18-2019, 10:01 AM   #15
philipswanson
Probably not from rust. More likely from a porous casting of pot metal.
Old 06-18-2019, 10:48 AM   #16
tubman
tubman's Avatar
A direct quote from the original post.
Old 06-18-2019, 04:30 PM   #17
tubman
tubman's Avatar
Here's what I have. Oh, by the way, after I looked at it, I don't think it will fit in a "Small Flat Rate Box". Better plan on over $10 for shipping.
Old 06-19-2019, 08:11 AM   #18
Zax40
Yeah, that's the one. I measured just the cast part and it's right around 3 inches tall. I think between the two I could make one good one. I'll send you a private message.
Thanks
Thread Tools
Display Modes
