12-03-2014, 09:02 PM | #1 |
Double venturi
I am rebuilding a early '28 carb that was meant to be a double venturi but it is missing. Can a single venturi be used and will it still perform well? The jets are in line and are close together.
12-03-2014, 10:07 PM | #2 |
Re: Double venturi
The correct venturi is sold by most suppliers. It might run with the later one, but I would bet it would not run well. Rod
12-03-2014, 10:13 PM | #3 |
Re: Double venturi
I use the correct part, here is the info from Synders, others sell them also.
Double Venturi
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
12-04-2014, 02:31 AM | #4 |
Re: Double venturi
Your Zenith should have a little pin installed on one side where the double venture mounts. Often they have been ground off to accommodate the single venture. The double venture has slots in it the pin goes into to prevent the venture from rotating.
Tom Endy |
12-04-2014, 04:12 AM | #5 |
Re: Double venturi
