Old 01-25-2020, 04:01 PM   #1
Conaway2
Conaway2's Avatar
Default Roadster door hinge screws
I cannot find correct screws that fasten the body hinge to the body. I’ve bought roadster door hinge screws from two suppliers and the screws don’t fit. In one case, the diameter is about right, but the threads are too fine.
Does anyone know the correct screw size, and where to get them ?
Many thanks
Jim
Conaway2 is offline   Reply With Quote
Old 01-25-2020, 04:34 PM   #2
Jim M
Jim M's Avatar
Default Re: Roadster door hinge screws
What year is your Roadster. My 29 Std Roadster has bolts with nuts that attach the hinge to the frame.
Jim M is offline   Reply With Quote
Old 01-25-2020, 05:22 PM   #3
Conaway2
Conaway2's Avatar
My roadster is a 1931. I’m missing one screw on the bottom hinge, and it appears to screw into the hinge. I can’t get the other two screws out to look at them.
Old 01-25-2020, 11:35 PM   #4
1928Mustang
Call Arizona model a parts. They have them .
1928Mustang is offline   Reply With Quote
Old 01-26-2020, 10:31 AM   #5
rotorwrench
rotorwrench's Avatar
Roy Nacewicz's fastener business "Ford Bolts" is now back up and running under new ownership "Third Gen Automotive". There fasteners are as accurate as they can make them. Here is a link.
http://fordscript.com/
Check under the Model A section for the open car door fasteners.
