Old 01-22-2020, 02:27 PM   #21
Tim Ayers
Default Re: Which Cam
Originally Posted by Russ/40 View Post
Yes, you could check it, but why do it twice. Suggest you view my tutorial on the original Techno site where i moderated for Bill.
https://web.archive.org/web/20160318...g/clayhead.htm
Wait for photos to load, as they are archived.
Got it.
Old 01-22-2020, 06:28 PM   #22
Ol' Ron
Ol' Ron's Avatar
I like t use aluminum balls. They retain their shape and are easier to measure, giving a more accurate results. I used clay for many years, but found the alum balls better and easier to use. I don't think the piston dome shape inrelation to the dome in the head is important in a street engine just get the pottom edge of the piston to head clearance down to around .040.,050, SBC is .o35.
Old 01-23-2020, 07:15 AM   #23
40 Deluxe
Originally Posted by Ol' Ron View Post
Having used "Many L-100 cams, I can "Honestly" say: they don't work very well in a relatively stock engine. Having too mucj duration and overlap, which kills low end torque. These cams need some displacement and compression o replace that. They run well in bigger engines. However if you want a beter cam try the Isky 1007B. But I gess if you already have these other cams, either on should work OK
I've heard the L-100 described as the "smiley cam". Does this mean it has a nice lopey idle, but is not a good cam for a street car?
Old 01-23-2020, 08:33 AM   #24
Ol' Ron
Ol' Ron's Avatar
Yes, the sound is exceptionally well liked as the sound of a flathead. Installed in a large displacement , hi compression engine and properly tuned. I can give excellent fuel economy as well as excellent power in a heavy car.. The biggest problems with most builds is improper tuning. This has been solved by both Bubba and Charley NY. Unfortunately, after spending many$$$$$$, they don't tunne them properly. The "tuning of a flathead" has ben discussed on this forun a dozen times, and it works.
Old 01-23-2020, 09:17 AM   #25
KiWinUS
KiWinUS's Avatar
Here is Bryan Kilsby"s stunning car, I believe he has over 10,000 miles on this awesome sounding & running engine. Idles @ 600 rpm .
Enjoy
https://www.youtube.com/watch?v=SXvnDP25924
Old 01-23-2020, 11:13 AM   #26
philipswanson
[QUOTE=Ol' Ron;1844355]I like t use aluminum balls.
Where from? Aluminum foil?
philipswanson is offline   Reply With Quote
Old 01-23-2020, 11:49 AM   #27
KiWinUS
KiWinUS's Avatar
Correct Phillip
Old 01-23-2020, 12:00 PM   #28
shoe box Jack
I have an isky 77B in my 49 ford with 260 ci. 378 gear I have 127000 miles on this build and all is good. I would use this cam on my next build. Jack.
shoe box Jack is offline   Reply With Quote
Old 01-23-2020, 01:29 PM   #29
Zeke3
Zeke3's Avatar
Kiwi, that is a sweet sounding engine and the cars looks great also. I was thinking that would make some inspirational background music for the shop.
Zeke3 is offline   Reply With Quote
Old 01-23-2020, 02:48 PM   #30
Tim Ayers
Hey Jack,
To confirm, you has 127,000 or 12,700 miles?
If it's 127,000, that's impressive.
Old 01-23-2020, 03:01 PM   #31
frnkeore
frnkeore's Avatar
A 400 Jr, for comparison. I think he could have got it to idle a little lower though.
https://www.youtube.com/watch?v=5pCzCktcif8
Frank
'35 Ford Model 51
'48 Ford F3
frnkeore is offline   Reply With Quote
Old 01-23-2020, 04:47 PM   #32
40 Deluxe
Thanks, Ron I'm building a 296 with either 81A or EAB heads (depends on which block I use) for my '40 sedan. Would the L-100 work on the street?
Old 01-23-2020, 05:16 PM   #33
john in illinois
john in illinois's Avatar
Russ I have a Schneider 248 f in my roadster. Have a .325 rear end.
I am very happy with the way this cam drives. It will putt along on country roads and has a lot of power on the Highway
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 01-23-2020, 05:22 PM   #34
Bored&Stroked
Bored&Stroked's Avatar
Yes - you have enough cubic inches to make it work well. What compression ratio are you headed toward? Mill the heads and get .040 over the pistons - makes a big difference. If you're in a light enough car (sedan might not be it) and have the right gears, could even go to a Potvin 425.
Old 01-23-2020, 06:44 PM   #35
KiWinUS
KiWinUS's Avatar
Mate thatís a great idea. It sure is a sweet sound. Runs bad as also
Old 01-23-2020, 11:26 PM   #36
Ol' Ron
Ol' Ron's Avatar
It does sound good, but it's running awful rich. The biggest problem I have with 97 carbs is tuning them for economy. The best carb I;ve found is the 500 cfm Edelbrock. Richard gor 22 mpg wiyh the 276 in a 3800l 53 Ht. AF i n cruise was 15.5, 13 at WOT and an L-100 cam
Old 01-24-2020, 11:16 AM   #37
shoe box Jack
HI Tim, Yeas I have 127000 miles on the car I have owned the car for 20 years we are both retired and when I bought the car I rebuilt the car bumper to bumper we attend 2 cruse nights a week and 1 or 2 car shows every weekend we will take a week and go on a week or so trip. As you can see we use the car a lot and have some trips planed for this sumer. Jack.
Old 01-24-2020, 11:33 AM   #38
Tim Ayers
That's awesome!
