Old 01-19-2020, 06:25 PM   #1
Russ/40
Russ/40's Avatar
Default Which Cam
I am building a 81A block. Cam choices, because I have them, Schneider 248 and a Isky 77B. Car is a 40 sedan with 3/78 gears, Merc crank, single 97. Stock iron heads. I know the 77b is almost as stock, but would someone who knows these cams describe the nature of the 248 compared to the 77B?
Old 01-19-2020, 06:49 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Which Cam
Well, the duration is the same for both 220 degrees at .050 -- the 77B only lifts about .325, while I believe the 248F lifts .350. When I sent to Schneider's site - they showed two different lift options . . . one about .320 and the other .350. Truth be told, I'd probably not run either of them - they are very mild cams (but hey, I know - you have them). I'd much rather see you use an Isky 1007B - would sound good and run well . . . and to me, I like BOTH in a period car.
Old 01-19-2020, 07:19 PM   #3
KiWinUS
KiWinUS's Avatar
Any one that has ever “honesty “ used one would recommend an L-100
Cheers
Tony
Old 01-19-2020, 07:56 PM   #4
Bored&Stroked
Cheers
Tony
I gotta ask Tony . . . how do you "dishonestly" use an L-100??
Old 01-20-2020, 10:00 AM   #5
Ol' Ron
Ol' Ron's Avatar
Having used "Many L-100 cams, I can "Honestly" say: they don't work very well in a relatively stock engine. Having too mucj duration and overlap, which kills low end torque. These cams need some displacement and compression o replace that. They run well in bigger engines. However if you want a beter cam try the Isky 1007B. But I gess if you already have these other cams, either on should work OK
Old 01-20-2020, 11:51 AM   #6
drolston
drolston's Avatar
Can't compare to the Isky, but the Schneider 248f I run in my 284 inch flathead is very good in traffic, and has the low end torque needed to perform very well with the 3.25 rear end gears I have in my '41 coupe.
Old 01-20-2020, 01:49 PM   #7
Russ/40
Russ/40's Avatar
Thank you for your advice and perspectives.
Old 01-20-2020, 06:37 PM   #8
Ol' Ron
Ol' Ron's Avatar
I would think any cam would run well in a 284 ci engine. But in a stock engine you have to be conservative.
Old 01-20-2020, 08:36 PM   #9
Zeke3
Zeke3's Avatar
I understand Ol Ron's comments much better after reading the first half of JWL's book "Flathead Facts".
Zeke3 is offline   Reply With Quote
Old 01-20-2020, 08:48 PM   #10
Ziggster
I have the 1007B, but it will be a few months before I can get the engine up and running. Hope it works on a stk engine (C59A) with just a 0.060" overbore.
Ziggster is offline   Reply With Quote
Old 01-20-2020, 11:52 PM   #11
Ol' Ron
Ol' Ron's Avatar
The best modification you can make to a stock or mild modified engine is piston to head clearance. This increases the turbulence in the chamber and better combustion. This improved fuel mileage and better throttle response. Plus, it's not that expensive.
Old 01-21-2020, 04:03 AM   #12
Ziggster
Good to know. I have the factory relieved heads. I think compression ratio is about 7.3:1 with my 0.060" o reborn according to the big chart someone made a while back.
Old 01-21-2020, 07:53 AM   #13
Ol' Ron
Ol' Ron's Avatar
Those charts are for reference only. You actually have to measure the chambers to determine the CR. In my book I measured a dozen or so heads and they were all over the place. Another consideration is the difference between Static and Dynamic compression. This is determined by the closing of the intake valve. An L-100 cam drops an 8: 1 CR to around 6:1. Good reason to have more cubes.
Old 01-21-2020, 12:44 PM   #14
Bored&Stroked
Post was off topic . . . so I deleted it. Sorry bout that!
Old 01-21-2020, 01:43 PM   #15
Russ/40
Russ/40's Avatar
Ok guys and gals, a simple attempt to gather info to assist me in choosing between two cams, seems to have become a tutorial on building an engine. I'm sure many need and value this information, but I am familiar with the issues brought to light and familiar with building V8 flatheads. My only request, was for a cam comparison. Can we stick to the question asked.
Old 01-21-2020, 05:13 PM   #16
tubman
tubman's Avatar
OK. I don't see why anyone, after looking at the specs of all cams available for your engine, would even consider the 77B. I went through this a couple of years ago when I was deciding whether to put an Isky MAX-1 in the '51 Merc engine I put in my '51 Ford Club Coupe. After a bunch of research (including this site : https://www.tildentechnologies.com/C...erformance.htm, I decided to keep the stock 8CM cam. From the overall experience since then, I believe I made the correct choice.
Also, I am in complete agreement with "Ol' Ron" about taking care of the heads FIRST.
Old 01-22-2020, 11:00 AM   #17
Russ/40
Russ/40's Avatar
Originally Posted by tubman View Post
OK.
You won't know what the heads need until the cam and valves are in.
Old 01-22-2020, 11:40 AM   #18
Tim Ayers
You can certainly check space above the pistons (squish) before the cam. Unless you change the pistons, that should be consistent.
Old 01-22-2020, 12:19 PM   #19
Russ/40
Russ/40's Avatar
Yes, you could check it, but why do it twice. Suggest you view my tutorial on the original Techno site where i moderated for Bill.
https://web.archive.org/web/20160318...g/clayhead.htm
Wait for photos to load, as they are archived.
Old 01-22-2020, 02:17 PM   #20
philipswanson
Russ/40. Great information on measuring valve to head clearances. Thanks for posting it.
philipswanson is offline   Reply With Quote
