Old 10-19-2014, 02:03 PM   #1
FrankWest
FrankWest's Avatar
Default rubber front floor mat
Does the mat just lay there? or should it be tacked down somehow?
FrankWest is offline   Reply With Quote
Old 10-19-2014, 02:06 PM   #2
mfagan
mfagan's Avatar
Default Re: rubber front floor mat
I believe there are snaps that hold it down.
mfagan is offline   Reply With Quote
Old 10-19-2014, 02:10 PM   #3
ford38v8
ford38v8's Avatar
For the EFV8CA Concourse, it should have the two hold down buttons on the '37-'38 models. I think also on the '36, but beyond that, I haven't a clue.
In my experience though, the buttons are not needed in service, and in fact can be a nuisance.
Alan
Old 10-19-2014, 02:47 PM   #4
TonyM
TonyM's Avatar
Alan, where are the hold down buttons on 37-38?
TonyM is offline   Reply With Quote
Old 10-19-2014, 03:04 PM   #5
v8fordman
v8fordman's Avatar
You will find two holes on each side of the shifter opening of your transmission cover... on the flat part. This is where the buttons go.
v8fordman is offline   Reply With Quote
Old 10-19-2014, 03:33 PM   #6
Joe Immler
How about hold downs for a mat in a '41 Ford? I never saw any and mine slips around when I get in.
Joe Immler is offline   Reply With Quote
Old 10-19-2014, 03:55 PM   #7
Old Henry
Old Henry's Avatar
My original style mat for my 47 has no connections to the floor. I put down a plastic moisture barrier then the stock style rag padding under the mat. It can't move because of the slots that fit around the front seat bracket, the hole that fits around the dimmer switch and radio switch plus the gas pedal. Plus, the edge fits under the molding on the edge of the floor above the running board.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 10-19-2014, 04:23 PM   #8
DavidG
DavidG's Avatar
Guys, he's asking about a '33, not a '37 or '47.
The attached chart shows the push pin locations for the front floor mat (amongst other fasteners) in a '33-'34 by body type. This applies to the original type of two-piece mat where the larger portion overlaps the smaller portion around the transmission shift lever housing and hand brake.
File Type: jpg 33-34 floor pan plug button locations.jpg (46.3 KB, 90 views)
Old 10-19-2014, 09:23 PM   #9
Ford Freak
It just lays there on my '52 F-1 . Doesn't move at all .
Ford Freak is offline   Reply With Quote
Old 01-16-2020, 05:02 PM   #10
JMFL36
JMFL36's Avatar
DavidG, thanks for the chart. It's gold, Jerry, gold!!!
Does anyone know where I might find the "button" fasteners identified as #3 in the chart? My '34 Phaeton has four of the male parts of the "button" in the floor in locations 7 and 8 in the chart. But I'm missing the two males at location 6, and all six female parts that "button" the mat to the floor.
Thanks in advance!
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 01-16-2020, 05:43 PM   #11
Kube
Kube's Avatar
Dave, How did you know what year he was asking about? I know you are good. Rael good in fact but still...
Old 01-16-2020, 05:44 PM   #12
Kube
Kube's Avatar
You original mat did in fact have a number of fasteners that held the mat in place.
Old 01-16-2020, 05:45 PM   #13
JSeery
JSeery's Avatar
Because he has helped Frank a lot and Frank has a 33 4cyl.
Old 01-16-2020, 06:05 PM   #14
DavidG
DavidG's Avatar
JMFL36,
You might try Michael Driskell at Third Gen Automotive in McMinnville, TN for the ones you are missing. Some of them are made of 'unobtainium', however.
Old 01-16-2020, 06:13 PM   #15
Kube
Kube's Avatar
Okay, now I understand. I suppose I should have known that.
Old 01-16-2020, 06:15 PM   #16
35fordtn
35fordtn's Avatar
Thanks in advance!
I certainly have a limited few of the males and females. the female portion is just basically impossible to find in NOS form.
35fordtn is online now   Reply With Quote
Old 01-16-2020, 06:17 PM   #17
DavidG
DavidG's Avatar
Mike,
As JSeery indicates. our Mr. West (not his real name) is a frequent thread starter. Of late into Hupmobiles and John Dillinger's preference for them.
Old 01-17-2020, 08:17 AM   #18
JMFL36
JMFL36's Avatar
Thanks for the info. I emailed Mike to see if he's got any. Otherwise, I'll just match up the size and color with a modern snap like the ones you see on leather and denim and such. Lots of choice on eBay and elsewhere. I'll post here to let everyone know what I end up with. Thanks again!
