Old 12-31-2019, 08:45 AM   #1
flathead48
flathead48's Avatar
Default Radio repair
Where is best place to send 6volt + am radio, works but poor reception
Thanks,
Happy and Healthy New Year to all
flathead48 is offline   Reply With Quote
Old 12-31-2019, 08:57 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Radio repair
before sending a radio, that works, out for repair look at the antenna make sure it is in good condition and grounded properly then tune the antenna to the radio.
Old 12-31-2019, 09:10 AM   #3
marko39
Also check to see if car has the extra condensers installed. You should have one on generator, voltage reg, and oil sender to prevent static.That is what I've seen for my 39. There may be more.
marko39 is offline   Reply With Quote
Old 12-31-2019, 10:27 AM   #4
flathead48
flathead48's Avatar
Thanks guys, was thinking along converting to fm ?
Old 12-31-2019, 11:09 AM   #5
philipswanson
Got my 40 radio modified so it gets AM, FM but more importantly has a thumb drive that I use exclusively. Constant music with no static. Downloaded MP3 from the net. Went to a guy in Florida. He can do 6v or 12v. Not cheap though. Radio will be stripped except for the tuner and converted to solid state. I went with the Aurora conversion and larger speakers under the front seat. Sounds great, still on 6 volts positive with a 12V negative tap for 12 v accessories. The old original radios were not very good and tons of static.
philipswanson is offline   Reply With Quote
Old 12-31-2019, 12:24 PM   #6
cas3
there is a jillion radio thread here, just search "radio fordbarn" at google and you'll know it all. i want the aurora conversion myself, maybe a late christmas present from me to me
Old 12-31-2019, 12:47 PM   #7
FrankWest
FrankWest's Avatar
https://redirad.com/
if you are having connection problems but you radio actually is operating.
this worked great for my glovebox radio connectivity.
I also purchase a tiny player that also is an fm radio
I can play 1930;s music in rather than listen to Lady Gagga
https://shop.westerndigital.com/prod...MX24-008G-A46Y
FrankWest is offline   Reply With Quote
Old 12-31-2019, 01:10 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Tune it to the antenna--- usually near where the antenna wire goes in is a small adjustment screw in a hole--- antenna trimmer capacitor--- makes all the difference in reception-- I forget if best at low end or higher end of dial, start with weak station and adjust to best reception
Kurt in NJ is online now   Reply With Quote
Old 12-31-2019, 01:54 PM   #9
HDowse
HDowse's Avatar
Try Joe at Classic Auto Electric. He converted my 1940 Zenith to am/fm and it sounds great.
Joe Dickhudt
joe.dickhudt@classicautoelectric
HDowse is offline   Reply With Quote
Old 12-31-2019, 03:55 PM   #10
flathead48
flathead48's Avatar
Thanks guys for all the info , I appreciate your time to respond
