Old 12-31-2019, 11:16 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Ways to Start With Obstructed Hand Crank
I had to have a tool box between the front frame rails of my 190A because I do some out-of-state traveling each year. I chose the rectangular tool box because it holds more stuff than the the curved box.
Installing a tool box between the frame rails blocks access to hand-crank-start the engine. So given this disadvantage, and the starter fails to work, how could the engine be hand-cranked to start?
The tool box I speak of is attached to its mounting bracket with 4 screws, so it is removable. It's a good idea to use cage nuts or other captive type nuts to facilitate roadside removal. However it's a pain to empty my filled-to-the-brim tool box especially if the weather is inclement.
Another simple modification would be to add access holes through the tool box to accommodate a lengthened hand-crank. Plastic push-in caps would seal the holes in the box. This will be my solution because it minimizes the stuff I will need to take out of the tool box.
Bob Bidonde
Old 12-31-2019, 11:36 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Ways to Start With Obstructed Hand Crank
Always park on hill
Old 12-31-2019, 12:41 PM   #3
super flat
super flat's Avatar
Put a piece of tubing all the way through your tool box and extend the hand crank.
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 12-31-2019, 12:58 PM   #4
Patrick L.
Patrick L.'s Avatar
Originally Posted by Kurt in NJ View Post
Always park on hill
LOL ! Just like owning an old Harley.
Old 12-31-2019, 01:05 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
This would work, get a V8 crank
Old 12-31-2019, 07:17 PM   #6
Big hammer
Always park on hill
Push it to a hill ! 50 years ago I was pushing it a lot.
get a bigger hammer tap done
Old 12-31-2019, 07:38 PM   #7
Charlie Stephens
Bob,
Your car looks great and I assume it has a good battery. I wouldn't expect a problem, and wouldn't waste my time preparing for a problem that might never occur. In rare case of a problem, look for a couple of friends for a push, or call AAA for a jump. Or remove the box on the road for that rare occurance.
Charlie Stephens
Old 12-31-2019, 09:02 PM   #8
Ruth
Wow Bob! That is a BIG Bax. It appears you could just drill a hole in the back for the crank, remove all you stuff and crank the engine with the crank INSIDE the box!
Old 12-31-2019, 09:09 PM   #9
jm29henry
jm29henry's Avatar
Look at Snyder catalog they sell a special wrench it may help you
jm29henry is offline   Reply With Quote
Old 12-31-2019, 10:30 PM   #10
TerryH
TerryH's Avatar
I have had two A’s over a long time period and never needed or used a crank....
TerryH is offline   Reply With Quote
Old 01-01-2020, 01:20 AM   #11
The Master Cylinder
The Master Cylinder's Avatar
I don't think I would try to start an engine with Snyder's "Special Wrench".
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-01-2020, 03:30 AM   #12
cpf240
cpf240's Avatar
Carry a pull-start rope from a lawn mower. Wrap it around the crank pulley and give it a strong yank!
cpf240 is offline   Reply With Quote
Old 01-01-2020, 10:22 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
I would prefer not to block the crank hole . My repro tool pouch holds everything that I feel that I might need and easily fits under the seat .
Old 01-01-2020, 11:44 AM   #14
Jim/GA
Jim/GA's Avatar
I've seldom had a starting problem in the many years of driving a Model A. Twice, I think, in 30 years. Starter bendix jammed once, starter brushes wore out the other time.
In both cases I did a push start, popping the clutch with the transmission in 2nd gear, and the engine was running after the car was pushed about 10 feet. You enlist the aid of 2 or 3 people who gently push you and you pop the clutch. Off you go!
Much safer than hand cranking an engine that may kick back.
Jim Cannon
"Have a Model A day!"
Old 01-01-2020, 05:14 PM   #15
Purdy Swoft
If its a sedan, make sure that the friends push by the rear bumper instead of the rear body panels ! There is too much risk of bending when the car is pushed by the rear body panels .
