Old 09-15-2021, 10:17 PM   #1
kustoman
Default 1935-36 headlight differences
From previous posts I understand that headlight bucket for 1935 & 36 passenger cars and some pickups are the same apart from mounting studs, so then the diameter where the glass retaining ring fits is the same.
I see that the stainless steel band that mounts the glass is quite different, and the 35 glass is a lot flatter, but is the glass diameter the same, where it fits the band?
I have a 1936 5 window coupe and am looking at fitting 7" sealed beam lights. I have seen these fitted directly to trim rings, are these factory or aftermarket?
kustoman is offline   Reply With Quote
Old 09-15-2021, 10:49 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 1935-36 headlight differences
1935 Ford V8 Headlights.
Old 09-15-2021, 10:49 PM   #3
mercman from oz
1936 Ford V8 Headlights.
Old 09-15-2021, 11:17 PM   #4
Brian
Brian's Avatar
Those sealed beam conversions were standard equipment on about '41 big trucks, which used the same h'lite buckets as 35-36 passenger cars.
Old 09-15-2021, 11:53 PM   #5
kustoman
They would take a bit of finding now, I guess. Some guys are putting sealed beams behind original fluted lenses, but that does not seem a good thing to me.
Old 09-16-2021, 12:07 AM   #6
Randy in ca
Randy in ca's Avatar
I think most of the info you're after is in this old thread:
https://www.fordbarn.com/forum/showthread.php?t=224322
Believe I still have a high quality NOS sealed beam conversion for 1935-36.
I'll see if I can find it if you might be interested.
Randy in ca is offline   Reply With Quote
Old 09-16-2021, 06:30 PM   #7
kustoman
Hi Randy,
I have a Bob Drake reflector kit, but apparently they don't focus well, so the sealed beam route seems better.
I am interested in what your kit is like, the conversion has to look good, so otherwise I might be able to take Brian's suggestion and see if I can find some big trick trim rings, the rest is available.
Old 09-16-2021, 07:15 PM   #8
Brian
Brian's Avatar
It is possible to get quartz halogen bulbs that fit the original reflectors. I've run them for years, means you can use your original bulging 36 h'lite lenses
Old 09-18-2021, 11:53 PM   #9
Randy in ca
Originally Posted by kustoman View Post
Hi Randy,
I had a look at the conversion kit I have today. Can't post pictures - in the process of moving to a new computer and need an adapter to upload to the new one. Here's a scan of the original instruction sheet that came with the kit. Hard to guess how well it would look without actually putting things together - my guess is that it would look fairly good with a bezel from 1935 car or the later trucks. 1936 bezels are so much wider it's hard to say. I assume that the spring assemblies in the kit are to allow adjustment to make up for the different bezels. This kit is specifically stated to be for 1935 & 1936 Ford.
Probably should have done this by Private Messaging. Have a look, see how you make out alternately and let me know if you might be interested in these.
File Type: jpg Instructions - 1935-36 Sealed Beam adapters.jpg (68.1 KB, 69 views)
Old 09-18-2021, 11:58 PM   #10
Tinker
Tinker's Avatar
36 Buckets and the hollow bolts go to at least 38 trucks. The bucket bolts are hard to find.
Old 09-20-2021, 12:14 AM   #11
kustoman
Hi Randy,
That's a real piece of history you have there, I have seen a few cars with this type of kit.
I think you are right about the 36 bezels, I have been looking at options and I can get repo big truck bezels that fit 7" halogen or sealed beam lamps without needing an adaptor space ring. The rest of the bits are standard parts that I can buy locally in New Zealand, so thanks for your help Randy and thanks Brian for the hot tip about the big truck bezels.
