Old 07-10-2019, 01:30 PM   #1
tagroff
tagroff's Avatar
Default 1928
Hi Guys looking for a few suggestions. My truck will start fine when cold runs for approximately 8 minutes each time shuts off and refuses to start again. At that time I have no spark but do have gas. If i let sit till the next day it will again start right up.....Thanks ahead of time for your help
Tim
1928 Roadster Pick Up
tagroff is offline   Reply With Quote
Old 07-10-2019, 01:50 PM   #2
31Tudor
31Tudor's Avatar
Default Re: 1928
Symptoms of a bad coil.
31Tudor is offline   Reply With Quote
Old 07-10-2019, 01:51 PM   #3
aermotor
Default Re: 1928
Coil or condenser bad.
John
aermotor is offline   Reply With Quote
Old 07-10-2019, 02:03 PM   #4
marty in Ohio
marty in Ohio's Avatar
Default Re: 1928
Sounds like a condenser to me. Don't ask me how I know that!!
Marty
marty in Ohio is offline   Reply With Quote
Old 07-10-2019, 03:03 PM   #5
Mulletwagon
Mulletwagon's Avatar
Default Re: 1928
Would be worth checking continuity of all ignition wiring and also checking to ensure there is voltage to the coil during the no-start condition. Many more coils are replaced than are defective.
Mulletwagon is offline   Reply With Quote
Old 07-10-2019, 04:01 PM   #6
Jim/GA
Jim/GA's Avatar
Default Re: 1928
What you describe is classic bad condenser problem. They become heat sensitive and short out internally when hot.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 07-10-2019, 05:42 PM   #7
1crosscut
1crosscut's Avatar
Default Re: 1928
Replace the condenser first and see if that helps. Cheap and easy. Replace the coil second if that doesn't help. Only do one at a time that way you know what fixed it if it does.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-11-2019, 07:00 AM   #8
tagroff
tagroff's Avatar
Default Re: 1928
Thanks for your suggestions I did pullthe coil wire when it quit and no spark to the coil wire. Today I will replace the condenser and see what happens again thanks for your replies.
Tim
Old 07-13-2019, 11:45 PM   #9
tagroff
tagroff's Avatar
Default Re: 1928
Thought I'd give you an update. It's not the condenser. I believe its the ignition cable once I started moving it around I again had spark when it quit again I wiggled actually screwed the cable out some more and again had spark. I will pro ally replace the ignition cable..
Tim
Old 07-14-2019, 06:04 AM   #10
Steve Plucker
Default Re: 1928
"Pro ally"...Never heard that expression before!
I need to go over my coupe...got something wrong with it also.
Hope you found the problem.
Pluck
Old 07-14-2019, 12:56 PM   #11
tagroff
tagroff's Avatar
Default Re: 1928
Haha guess I should check my spelling ..I'm sure you will find your problem...Good Luck
Tim
Thread Tools
Display Modes
