Old 04-14-2019, 10:42 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Looking for Wind Wings
I am looking for Wind Wings like the ones pictured below. My doors already have the holes.
[IMG][/IMG]
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-14-2019, 10:49 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Looking for Wind Wings
How big can you make that photo?! Try a Bratton's model A catalog, or maybe Snyder's or any other.
Old 04-14-2019, 11:41 PM   #3
Chris Haynes
Already checked those. They don't have that type or parts for them.
As for the picture, I have no clue why it came out so big. I have posted dozens here the same way without a problem.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-15-2019, 12:10 AM   #4
J Franklin
J Franklin's Avatar
Part # 25390 in bratton's catalog is exactly what is in your photo. What do you find different? Please inform me.
Old 04-15-2019, 06:21 AM   #5
marty in Ohio
marty in Ohio's Avatar
Look at the Snyder's catalog, page 188 - 189. Looks like everything you need.
Marty
marty in Ohio is offline   Reply With Quote
Old 04-15-2019, 08:56 AM   #6
Gary WA
Gary WA's Avatar
wind wings
www.whidbeymodelaclub.com
Old 04-15-2019, 09:29 AM   #7
gridleak
gridleak's Avatar
Default Re:INFO NEEDED
INFO NEEDED I have a pair like those that I want to install on my 29 coupe. I believe that they should installed so that the brackets are centered on the ridges on the door and the wing vertically centered using spring washers. But I need to know where they should be positioned for and aft.
gridleak is offline   Reply With Quote
Old 04-15-2019, 10:24 AM   #8
1931 flamingo
1931 flamingo's Avatar
They were an accessory, so put them where you want. New ones might have a template??
Paul in CT
Old 04-15-2019, 11:27 AM   #9
Chris Haynes
Thank you. Those didn't show up on my search.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-15-2019, 03:39 PM   #10
woofa.express
woofa.express's Avatar
I purchased the wind wing hinges from Snyders and the kid included a template of the glass. I simply had them cut. I did have them drop out and break on two occasions and replaced the rubber gaskets with two sided sticky tape, thick tape and they have been secure since. Be sure you get positioning correct as to reset is difficult and messy.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
