01-23-2022, 06:30 PM | #1 |
Water Pump - How to tell which one I have?
Hi all - in reviewing how to lubricate the Model A, everything says that you MAY have to lubricate the water pump, depending on which one you have. But nowhere that I can see does anyone tell you how to determine which one you have and whether you have to put grease in 1, 2, or 0 fittings. Is there a quick way to figure this out?
Thanks in advance. |
01-23-2022, 07:31 PM | #2 |
Re: Water Pump - How to tell which one I have?
If the fitting will take grease give it a little. If not and is not a dummy, clean it out and give a squirt. If it is not meant to have grease it won't take any.
01-23-2022, 07:42 PM | #3 |
Thanks - I'll take a look tomorrow
01-23-2022, 10:08 PM | #4 |
Leakless Model A Water Pumps will this help
www.whidbeymodelaclub.com |
01-23-2022, 11:53 PM | #5 |
01-24-2022, 08:15 AM | #6 |
