08-12-2020, 02:27 PM | #1 |
Clutch adjust.
Hi All,
Any tips or hints on how to go about adjusting the clutch on a 47 Ford v/8 flathead passenger car ? Thanks in advance for any info. |
08-12-2020, 02:53 PM | #2 |
Re: Clutch adjust.
you want about an inch, to inch ana half of free travel before you feel the pedal hit the pressure plate. to get this, get under the car, pull on the clutch pedal to study the way it works, then remove the pin on the fork so you can turn it which ever way in needs to go to get proper free travel at the pedal. sort of a generic how to as i am not a 47 guy, but most all cars are similar, just study how it works
08-12-2020, 04:11 PM | #3 |
Re: Clutch adjust.
make sure any and all the pedal bumpers are in place before adjusting.
08-12-2020, 06:25 PM | #4 |
Re: Clutch adjust.
There is a clevis attached to the clutch mechanism. You want to undo the pieces that will allow you to move the clevis on the threaded rod. This is the adjustment. It can be difficult to reach from the bottom. If needed, the front floorboard can be removed to greatly improve access.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
08-12-2020, 06:41 PM | #5 |
Re: Clutch adjust.
