11-10-2019, 09:20 PM | #1 |
Popping out Passenger side Exhaust
Not my car but trying to help out.
12v negative earth H & H flathead fitted with electronic ignition. Fitted with new 4 barrel 390 carb. Distributor is mechanical advance only. Checked advance and only shows 3 to 4 at idle and only around 12 at 3000 rpm. Know it should be around 24 degrees. Pops out passenger side only mainly at low speed. To check firing by removing a lead to see where the popping occurs I understand you need to ground the removed carbon lead t avoid damage to ignition unit? Hope to locate cylinder and go from there. Plan is a compression test, lead down check to locate the cylinder at fault. Possible this may be valve train related, sticky valve, a vaccum gauge at idle should show this up? Appreciate all comments. Phil NZ |
11-10-2019, 09:51 PM | #2 |
Re: Popping out Passenger side Exhaust
just check your manifold bolts are nipped up , might just be a vacuum leak. Your vacuum gauge will bounce a few Hg. if its a burnt valve it will be a lot more . just clip a timing light on each lead and watch it thats easy enough done too.
"Came too close to dying to stop living now!" |
11-11-2019, 07:52 AM | #3 |
stuck exhaust valve-try shorting out one cylinder on bank at a time to determine which cylinder
11-11-2019, 08:40 AM | #4 |
11-11-2019, 09:21 AM | #5 | |
And this can be confirmed with shorting out, vaccum gauge, and compression and leak down testing right? Also could be caused with a crossed HT lead. As its electronic distributor carbon core type wires are in use. To short out one cylinder at a time requires the lead to be earthed to block? Right? Thanks, Phil NZ |
11-11-2019, 09:18 AM | #6 |
it's running to free the sticky valve. G.M.
www.fordcollector.com |
11-11-2019, 10:56 AM | #7 |
Compression test --- quick and easy.
11-11-2019, 05:03 PM | #8 |
lead to block-correct, can be done easy if no insulator on plug wire, otherwise pull off one lead at a time till the popping stops. in a very rare instance you might get a crossfire if the wires are old or jammed together
11-11-2019, 05:12 PM | #9 | |
Phil NZ |
11-12-2019, 01:50 AM | #10 | |
I'm not sure how an electronic unit works but but if you can remove the plug at the coil/distributor end and have a spark gap to jump to it may be easier.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
11-11-2019, 11:17 PM | #11 |
As Flatjack mentioned, a compression check should check it. Don't make it harder then it might be. Granted sticky valves can show up under load and speed also. But at speed I'm not sure your pulling sparkplug wires. Then sticky valves underload... maybe mmo it a few times. (could use some diesel fuel bottle fed, but I prefer mmo over time or for results. Don't fill the tank with diesel!)
Vacuum gauge would show a dip or flutter. Compression gauge might lead to the cylinder it's happening. Not saying you can't with a open hood and someone sitting on the fender. My pops and uncle drove a car with the uncle running the throttle on the fender and my dad driving for a few miles to get it home. Different time. Compression checks are easy and should be done on any engine. If after you check vacuum and compression (standard mechanical diagnostic tools for old engines). It could be a miss fire from the electric ignition. I'd check the earlier first. Easy tools and checks. Last edited by Tinker; 11-11-2019 at 11:50 PM. |
11-12-2019, 02:00 AM | #12 |
A combustion engine is just a air pump. Well with a bit of fire! But if you pull a plug wire and it doesn't do it. well......
Best of luck! Last edited by Tinker; 11-12-2019 at 02:35 AM. |
11-12-2019, 02:33 PM | #13 | |
But read somewhere with carbon leads and electronic distributor it can cause damage to electronic unit. This is the point I am trying to clarify.As the car is a couple hundred miles away from me and want to be sure all options are considered. Thanks Phil NZ |
11-13-2019, 10:19 PM | #14 | |
So don't do that!. Lots of ways to skin the hypothetical cat. |
11-12-2019, 07:36 PM | #15 |
pull off the boot that is not supposed to be there and use a screwdriver to short out the plug--the fire/electric discharge will go to ground
