Old 01-05-2019, 05:17 AM   #1
Steve Plucker
Default After Sandblastig...What have you found...
After sandblasting a part, what have you found best to treat the part with before painting if left for a period of time?
Thanks.
Pluck
Old 01-05-2019, 07:49 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: After Sandblastig...What have you found...
Primer & then paint it.
Bill Shiny
"THE ASSISTANT GURU OF STUFF"
Old 01-05-2019, 08:25 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Phosphoric Acid. There is general metal prep at the big box stores that have Phosphoric Acid mixed in.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-05-2019, 08:40 AM   #4
Oldbluoval
Oldbluoval's Avatar
Brent-
Do you treat as such if priming within hours of the blasting?
Oldbluoval is offline   Reply With Quote
Old 01-05-2019, 09:14 AM   #5
Alaska Mike
I agree with Brent, phosphoric acid. I have kept parts for almost a year after treating with phosphoric acid. You can spray or brush it on. I use a foam brush for small parts, and usually treat everything I do.
Alaska Mike is offline   Reply With Quote
Old 01-05-2019, 09:59 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I like "picklex20", I have stuff hanging around that was treated over 5 years ago, the treated metal welds nicer too, on modern cars that live outside I have stopped repeating reoccurring rust bubbles from ordinary body shops with sandblasting, picklex20, epoxy primer--- more than 10 years with no signs of any rust
Old 01-05-2019, 10:17 AM   #7
daren007
Warped sheet metal.
daren007 is offline   Reply With Quote
Old 01-05-2019, 10:33 AM   #8
kimlinh
+2 Brent. Phosphoric acid works great. It stops the rust and gives the paint (primer) a good base. I use a product called Ospho, But there are others. Be careful some metal preps are mostly water with a little acid mixed in.
kimlinh is offline   Reply With Quote
Old 01-05-2019, 10:42 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Pluck,
In 1979 I used lacquer primer and a Rustoleum gloss black enamel top coat (fish oil base), and to date there are not paint failures or rust on those parts.
From 1998 to 2016 I used Krylon epoxy primer and Krylon gloss black enamel on parts that were absolutely rust free. I also used POR-15 Chassis Black epoxy on bare metal with a top coat of Krylon gloss black on parts that had some residual rust, and parts I wire brushed clean.
POR-15 adheres tenaciously to bare metal, clean or rusty but it fades when exposed to the ultraviolet rays in sun light. The Krylon top coat is cosmetic, to avoid fading.
Most importantly, all of my parts were cleaned with lacquer thinner before any painting.
When using POR-15 or other epoxy primers, you need to consider that these paints are very strong thread lockers. Also, epoxy paints adhere very well to human skin.
With POR-15, a little goes a long way. I did my the frame and most of the running gear of my 190A with just two half-quart cans applied by cheap throwaway brushes. Each part was given 2 light brush coats of POR-15. POR-15 flows so well that there are no residual brush marks.
Bob Bidonde
Old 01-05-2019, 01:18 PM   #10
chrs1961815
chrs1961815's Avatar
Spraying it with a very heavy epoxy primer that I use. If you drop it in water for a while it doesn't rust. It also can sit around for years.
chrs1961815 is offline   Reply With Quote
Old 01-05-2019, 01:33 PM   #11
J Franklin
J Franklin's Avatar
OSPHO - I use it always on fresh bare metal.
Old 01-05-2019, 08:01 PM   #12
burner31
burner31's Avatar
After blasting my fenders I found lead filler.
Old school repairs...no bondo
Side question: When did they start using bondo?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 01-05-2019, 08:05 PM   #13
Oldbluoval
Oldbluoval's Avatar
I had first hand knowledge in early 60's
It was a well known commodity then
Old 01-05-2019, 10:11 PM   #14
chrs1961815
Bondo was introduced in 1955, though a few products similar to it were around in the late 40's. It was originally meant to fill in small imperfections in metal but people got lazy and started filling dents with it that we see on our antique vehicles after they have been sandblasted today.
Old 01-05-2019, 11:52 PM   #15
Steve Plucker
Thank you all for the information...Will have to digest it all before I do some major parts cleaning.
Pluck
Old 01-06-2019, 09:17 AM   #16
BRENT in 10-uh-C
Originally Posted by Oldbluoval View Post
Brent-
No Bill, since there are many DTM primers ( -such as SelectPrime ) or even epoxies that can be applied first and then filler added to the top. Generally we use the Phosphoric to give us some 'hold time' between blasting and metal repair. Once finished we wash the metal with Wax & Grease remover to remove the Phosphoric from the pores.
BRENT in 10-uh-C
Old 01-06-2019, 09:25 AM   #17
Oldbluoval
Oldbluoval's Avatar
We're on exactly the same page on it
Old 01-08-2019, 07:37 PM   #18
Res731
Res731's Avatar
Do you have to remove the phospho before painting? I thought it can be used as an etch and can be painted over ?
Res731 is offline   Reply With Quote
Old 01-08-2019, 09:30 PM   #19
J Franklin
J Franklin's Avatar
Follow the instructions, you can paint directly over it.
Old 01-09-2019, 08:20 PM   #20
37 Coupe
37 Coupe's Avatar
Gibbs brand lubricant is another option and they state that it is safe for painting over it later. It is sold on Ebay and great as a rust preventative on guns and any metal. I have used it to prevent rust on metal sandblasted and cannot get to right away and clean later with mineral spirits or lacquer thinner than use the acid others have mentioned for adhesion. I think Gibbs is paint friendly cause of no silicones.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Thread Tools
Display Modes
