05-09-2020, 09:52 AM | #21 | |
Re: Tapping sound when Clutch pedal engaged
06-19-2020, 01:46 PM | #22 |
I just got done diagnosing a very similar noise. Ring gear was contacting the front face of the flywheel housing where there are some ribs in the casting, and only when the clutch was engaged. It's not just the starter bolts that the ring gear could be striking. The ring gear was .060 over the flywheel edge in two places. I had the ring gear reseated on the flywheel and everything is good. So, this clutch problem wasn't a clutch problem.
06-19-2020, 01:57 PM | #23 | |
I always suggest removing that one starter bolt closest to the engine, though, because it is so easy to do. If the end is shiny, then you KNOW the ring gear is rubbing against it. If the end of the bolt is not worn, you still need to remove the starter and look at the ring gear itself to confirm it is fully seated on the flywheel. So removing 1 bolt gets you started.
